Received OTA 4.4 on my never-rooted AT&T Note 2 I317. Looking to use some root-only app features, so followed instructions in the sticky thread for TWRP variant. Pretty much successful except for discrepancies noted below. However, apps report that the phone does not have root access. Powerup now has a long frozen pause followed by "unfortunately superuser has stopped". Once running, the "unfortulately" message comes up frequently. There's a Superuser app in the app drawer, but it immediately goes to the "unfortulately" message. Research here and in XDA suggests knox is stopping superuser. Several approaches to killing knox do not work until root is successful, which is no help. Knox removal based on going into the app drawer and opening knox fail because there's no knox icon in the app drawer. I did force stop on all processes named knox but it was no help. i read that supersu app would help but it says that there's no su binary installed and i need to re-root. re-rooting does not seem to change anything. Suggestions?
Update: I see some advice involving philz recovery and supersu, using odin 3.09, but every post I see says it's only for the note N7100. Can I use this on the I317???
my discrepancies:
1. odin could not find a recovery.tar.md5 file. i found a recovery.img file and i found instructions for converting .img to .tar.md5
2. at odin completion i wanted to see PASS before the phone rebooted however ODIN said RESET and phone rebooted before PASS. However, when putting phone into recovery it loaded TWRP so I felt that it had been successful.
3. TWRP failed MDF and zip signature checks on teamepic-root-from-recovery-v5.zip but if I allowed TWRP to ignore these warnings it said that installation was successful.
my discrepancies:
