Results 1 to 4 of 4
    Soli54's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Advanced options missing after upgrading note 2
    After upgrading my note 2 with the latest firmware in not getting the advanced option to go to clean delvik Also the touchwiz is gone.
    Downloading firmware from Sammobile is almost an impossible task as it takes hours n then gives a message saying download failed. Can anyone please let me know an alternative place to download the latest firmware?
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default Re: Advanced options missing after upgrading note 2
    How did you upgrade your device? The only way to specifically wipe the Dalvik cache would be if you had a custom recovery.
    Anyway, what model do you have? There are few other sites like rwilco and Samsung updates that still have some stock ROMs.
    Soli54's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by UJ95x View Post
    I updated via mobile odin.
    I have note 2.
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Soli54 View Post
    I have note 2.
    Have you checked those sites I mentioned?
    If you had a custom recovery and updated via Mobile Odin that would have replaced it with the stock recovery. You can't downgrade back to the old one if that's what you were trying to do.
    Sent from my Galaxy S4 running SlimKat 4.4.4
  1. Developer option gone?
    By CycloneSpoiler in forum LG Optimus G Pro
    Last Post: 08-26-2014, 10:52 PM
  2. Verizon/Unlocked Galaxy Note 3 White
    By Bl00dRunzC0ld in forum Marketplace Archive
    Last Post: 08-24-2014, 08:52 PM
  3. Verizon Data connection issue after root with LG G2VS980
    Last Post: 08-22-2014, 02:15 PM
  4. Upgrade my quad core tab Aynol Sword from 4.2 to kitkat 4.4
    Last Post: 08-22-2014, 12:16 AM
  5. phone freezing after 4.4.2 update
    By Unregistered in forum Ask a Question
    Last Post: 08-21-2014, 11:01 PM
