Results 1 to 3 of 3
    tmp3150's Avatar
    Banned
    Posts
    Global Posts
    1,208 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I need help with rooting the att note 2 with the 4.4.2 firmware
    I have a new (new to me), Galaxy Note 2 and I wanted to root it and remove the Knox. Can someone point me to correct file to use to root and remove the knox? I searched a few post, but it was a tad confusing.
    Here is what I am looking for:
    I want to root my phone and install that TWRP at the same time (this is the problem I having trying to find the proper file for the SGHI317. I then understand I download the SU app and use that to disable Knox. Or is it after I root the phone then disable Knox, then have the SU app disable the other portion of the Knox.
    Thanks in advance!!
  2. #2
    Darth_winnie2101's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: I need help with rooting the att note 2 with the 4.4.2 firmware
    Try using towelroot.com download install then run it and you should get root then just download twrp manager if you wamt twrp recovery or rom manager and install recovery. Then download a super user app...
    tmp3150's Avatar
    Banned
    Posts
    Global Posts
    1,208 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried the towelroot.com, but my device was not supported. Any other ideas?
  1. Replies: 8
    Last Post: 02-11-2015, 07:52 AM
  2. Free HTC battery for the taking
    By DSLAM in forum HTC EVO 3D Accessories
    Last Post: 11-11-2014, 05:36 PM
  3. LG G3 Circle Case with Wireless Charging
    By kilofoxtrot in forum Marketplace Archive
    Last Post: 09-01-2014, 03:16 PM
  4. Note 3 lag!!!!!
    Last Post: 08-26-2014, 10:35 AM
  5. clock widgets not keeping current time after root
    By neveser in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 08-25-2014, 07:08 PM
