Any word on the battery of the Note 2? Will it be easy to swap batteries? Anything about the size of the battery? My wife *really* wants one of these but is concerned about battery life. Thanks!!
For the record:
My Dell Streak has a 1580mah battery. It is a 5" screen and a 1-ghz single core processor. The Note 2 specs were released with a 5.5" screen, a 1.6ghz quad-core processor. But also a 3100mah battery. That's nearly twice the size of the battery on my older Streak.
I'm not going to make straight apples to apples comparisson, since that wouldn't be rightly fair. However, it seems as though Samsung definitely got this one correct by including a ginormous battery from the onset.
Secondly, the Galaxy S3 has a removable battery (if I'm remembering correctly), and I would say that the Note2 is following a lot of the same trends and design paths that the S3 has.
Thirdly, the original Note has a removable battery, 2500mah (again, if I am recalling correctly). I don't think Samsung would stray TOO far from this.
Huge on-board battery + its nearest cousin has a removable battery = most likely battery woes won't be a huge problem.
(Unless, of course, the S-Pen drains batteries poorly ... )
