Results 1 to 18 of 18
    corymcnutt's Avatar
    Posts
    Global Posts
    2,291 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Car Dock That Isn't a Universal Model?
    I would like to purchase a Car Dock that has a built-in plug for the phone to attach, and then have the charger cord plug into the Dock, not the phone...do they make such a thing for the Note 2? It seems like every model I have seen is a "Universal Holder" that basically holds the phone and a wire would stick out the side, if the phone is in a horizonal position (GPS use). The Car Dock that Moto makes is great...even Samsung's seems to be Universal.
  2. #2
    KahneFan's Avatar
    Posts
    Global Posts
    1,400 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Car Dock That Isn't a Universal Model?
    I accidentally ordered one for the N1 for my N2, I'll let you know if I can get it to work or not. Otherwise, if there is a dock like this for the 1, I'm sure there will be one for the 2 soon.
    corymcnutt's Avatar
    Posts
    Global Posts
    2,291 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by KahneFan View Post
    Where did you order the wrong one? I'd like to see it...Thanks!
  4. #4
    KahneFan's Avatar
    Posts
    Global Posts
    1,400 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by corymcnutt View Post
    See this posting: (see the top post in this series for the coupon code I refer to) http://forums.androidcentral.com/sam...ml#post2269856
    corymcnutt likes this.
  5. #5
    paynomind's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Looking forward to your answer if the 1 car dock fits the 2!
  6. #6
    saltysteve's Avatar
    Posts
    Global Posts
    421 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Why would it?? Aren't they different sizes???????
  7. #7
    KahneFan's Avatar
    Posts
    Global Posts
    1,400 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by paynomind View Post
    Nope. The length is what killed it. The width wasn't too bad actually. And, I contemplated just shearing off the tops of the brackets since I use my phone in landscape 95% of the time anyway. However, I never felt like I could get the charger to hold securely. So, I have a Note 1 dock cheap if anyone wants it :-)
    Quote Originally Posted by saltysteve View Post
    Yep. But, not by a whole lot. And depending on what you are using, sometimes not a whole lot will work. In this case, it doesn't (appear to for me).
  8. #8
    Sh3ngLong's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Samsung Galaxy Note II Charging Holder with Tilt Swivel and USB Cigarette Lighter Adapter by ProClip
  9. #9
    henning#CB's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is cool but it doesnt look like it will fit if I have a case on the phone...I have an XM skydock for my iphone and it would be a perfect solution but obviously not compatible. But something like it. It has an AUX port on the stem so all I do is mount the phone and squeeze the brackets in.
  10. #10
    lingo622's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The only thing I don't like about it is that it goes into the vents of the car. Those types of mounts never seem to securely stay in place in my car.
    Sent from my Galaxy Note II on Sprint using Tapatalk 2
  11. #11
    Sh3ngLong's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lingo622 View Post
    Not sure if you tried ProClips before, but the mounts are actually attached through the seams of the dashboard, not to the vent itself like other universal car mounts. For example, in the image above with the mount in front of the vent, the top portion of the mount is attached to the seam above the vent, while the bottom portion of the mount is attached to bottom seam of the vent.
    When attaching the mounts to the seams, you actually hear it snapping in, which means it's securely attached. My problem with these mounts is that sometimes I have a hard time removing them.
    These mounts are custom made to attach to your dashboard. You just have to put in your year/make/model of your car to find the right one for you.
    lingo622 likes this.
  12. Thread Author  Thread Author    #12
    corymcnutt's Avatar
    Posts
    Global Posts
    2,291 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would hope that Samsung will come out with one for the Note 2 - I just don't understand why they don't have them ready for the launch? When Moto released the Bionic, they had all kinds of docks and chargers available to buy immediately.
  13. #13
    lingo622's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sh3ngLong View Post
    Might have to give this a try then, cause I'm dying without my mount!
  14. #14
    iondokk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have posted a workaround for the. Note I holder for the Note II on xda in accessories, it works great. The only thing is that when you snap it in it does not trigger the docking software like the SIII did for me...
  15. #15
    WHaydock's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Brodit
    WarrenH
  16. #16
    crosshair's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I no longer use the CD player in my truck, so I have this mount being delivered today. Purchased it for under $25.00.
    Mountek nGroove CD Slot Car Mount #1 Top Rated, Best Seller List
    Mountek nGroove MT5000 CD/DVD Slot Universal Car Mount. Chech out their installation video under the "How to Install" link.
  17. #17
    iondokk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This problem has been resolved see the link on Xda...
  18. #18
    FishenFool's Avatar
    Posts
    Global Posts
    370 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try Craigs Dock at http://www.craigsdocks.com/samsung-galaxy-s3/
    Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
  1. Car Dock that fits extended battery
    By jdm2008 in forum Verizon HTC Rezound
    Last Post: 06-21-2012, 03:27 PM
  2. Cigarette lighter car dock that charges?
    By etnpnys in forum HTC EVO 4G
    Last Post: 01-07-2012, 08:28 AM
  3. Recommendation for Car Dock that Charges
    By dinc2new in forum Incredible 2 Accessories
    Last Post: 11-27-2011, 07:28 PM
  4. Best car dock that plugs into the cig lighter?
    By c0c0nutsp0rt in forum Epic 4G Accessories
    Last Post: 12-20-2010, 12:39 AM
  5. car docks that accommodate EVO cases while docked????
    By mynetdude in forum EVO Accessories
    Last Post: 09-04-2010, 03:48 PM
