Help with navigation..I changed a setting?![SOLVED]
So I was using navigation on my Note 2 (sprint) this weekend and everything was working fine. At one point it was having trouble locking a signal so I used GPS Status app to clear and re-download the A-GPS info. Once I did this, it seems my navigation switched from the normal display mode of you being on the bottom with the roads ahead going up on the display to an overhead, looking straight down map style version.
How the heck do I switch it back? (not sure if clearing/redownloading the A-GPS info caused it, or it was just coincidence).
Thanks.
Re: Help with navigation..I changed a setting?!
I'm having the same issue
Bump.
Anybody with any help?
Tap the compass needle in the top left corner.
Sent from my SPH-L900 using Tapatalk 2
Wow, I feel stupid now. Must have accidentally bumped it.
Re: Help with navigation..I changed a setting?![SOLVED]
Same thing happend to me. Took forever to figure it out.
