Results 1 to 6 of 6
- 11-12-2012, 11:18 AM
Thread Author #1
Help with navigation..I changed a setting?![SOLVED]
So I was using navigation on my Note 2 (sprint) this weekend and everything was working fine. At one point it was having trouble locking a signal so I used GPS Status app to clear and re-download the A-GPS info. Once I did this, it seems my navigation switched from the normal display mode of you being on the bottom with the roads ahead going up on the display to an overhead, looking straight down map style version.
How the heck do I switch it back? (not sure if clearing/redownloading the A-GPS info caused it, or it was just coincidence).
Thanks.Last edited by Wolvan; 11-13-2012 at 06:21 PM.
- 11-12-2012, 11:55 AM #2
Re: Help with navigation..I changed a setting?!
I'm having the same issue
- 11-13-2012, 11:09 AM
Thread Author #3
- 11-13-2012, 02:45 PM #4
Tap the compass needle in the top left corner.
Sent from my SPH-L900 using Tapatalk 2 - 11-13-2012, 06:21 PM
Thread Author #5
- 11-14-2012, 02:15 PM #6
Disaster - help with sign-in after google password change
By pleeho in forum Verizon Droid IncredibleReplies: 8Last Post: 05-22-2013, 10:43 PM -
Help with navigation. Please
By crwmlw in forum Verizon Droid IncredibleReplies: 10Last Post: 01-22-2011, 11:29 AM -
Help with global vibrate settings please
By hawaiian in forum Motorola Droid 2Replies: 0Last Post: 08-20-2010, 01:01 PM -
please help with navigation
By jmg1975 in forum Motorola DroidReplies: 5Last Post: 05-05-2010, 03:42 PM -
Help with Exchange settings
By Traprock in forum Motorola DroidReplies: 4Last Post: 03-16-2010, 09:37 AM
Reply
