You think the Zagg HD is aweful? Yes you put it on wet and if you know how to put it on correctly, you cant even tell that its on once it dries up cause of the HD clarity. What cloudiness are you referring to btw?
I'm not a fan of Zagg. I don't care for the orange peel effect it leaves. The texture just isn't the same as glass.
