Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By DAS
    Default What is the actual POCKETABILITY of the Note ?
    Sorry if it's bad form to post twice, I noticed my initial post was in the Sprint Note II fora...I figured the general Note one would get more answers.
    I'm seriously considering selling my s3 and paying the difference to buy one of these off contract.
    I've seen side by side comparisons w/ the S3, but what is the real life pocketability of the Note?
    Even if it fits in the pocket, is it awkward when walking or sitting?
    Does one handed operation work fairly well? I use my S3 one handed without any problems so I'm not too concerned about it, but just want to make sure it isn't too heavy to hold for one handed use.
    Thanks
  2. #2
    hopefulfarm's Avatar
    Posts
    Global Posts
    498 Global Posts
    ROM
    CM7 on the Nook Color
    Default Re: What is the actual POCKETABILITY of the Note ?
    I'm a back pocket gal. NO issues with a back pocket. Since you asked, I stuck it in my front pocket. No issues. However, I don't wear skinny jeans and I DO take it out of my pocket when I sit down because 1)i always do with any cell phone i've owned and 2) it would feel awkward.
    be careful tho with the rivets on jeans, can scratch the glass.
    Thanked by:
  3. #3
    I rock the phone in my front pocket and don't ever notice it. The tighter your pants the more difficult is going to be too get in or out. The only issue I've had is talking it out while sitting down.
    As for the weight for one handed use, the phone is super light for its size so I wouldn't worry about that all too much. I use it one handed all the time
    Sent from my Galaxy Note II on Sprint using Tapatalk 2
  4. #4
    Posts
    Global Posts
    498 Global Posts
    ROM
    I should mention I have a TPU case on mine and still no issues with pocketing.
  5. #5
    I find the device very pocketable. I typically wear a suit jacket, at work, during the day, and it fits fine in the inside pocket or the top pocket of my dress shirt. I also wear a belt clip pouch which I carry the Note in over the weekend when I'm wearing jeans, or when I'm just being lazy. I am a distance runner so I have an appropriate sized armband that I place the Note in when I'm out jogging.
    However, I would suggest you not make the pocketability of the Note your major consideration in deciding to purchase. The Note 2 is a device like no other, and some shifts in conventional thinking on how you handle the typical smartphone need to be made when using it.
    It's sheer size means that one handed use is not going to be practical in most instances. I for one have come to rely heavily on S-Voice (SV) for basic things like calling a contact, answering and declining an incoming call, texting, navigation, opening apps, setting reminders, and removing and editing appointments on my calendar (it actually works very well). I would also use SV to add appointments, but for some reason I can't get that feature to work right
    Because the Note 2 is really all about the s-pen ,you'll find if you use the s-pen with any regularity as I do (in meeting, conferences, and general note taking), that you will typically be holding the device with two hands because you'll have the pen in one hand, while you write, and holding the device in the other.
    In my opinion, and it's just my opinion, the Note 2 brings so many other value added features over a smartphone only type device (i.e., GS3, One X, G-Nex etc.) that in order to take advantage of these features one has to be willing to shift their mindset about how the device is carried and handled. Once you make that shift in thinking, you will find the benefits of the Note 2 far outweigh any limitations it has in pocketability.
    Thanked by 2:
    nlitenme likes this.
    jogging with it hasn't been an issue? can u send me a link to the armband that u use?
    I was worried it would be too big for jogging, but i love the GPS mileage tracking on my S3 and would like to continue using it on the Note.
  7. #7
    Here is the link to the armband. I actually purchased this one when I had the original Note, and after selling it I thought I would need to buy a different one, but to my surprise, with a slight modification to accommodate the headphone jack, the Note 2 fit perfectly fine.
    Amazon.com: BW Neoprene Sport Extreme Case Armband for AT&T Samsung Galaxy Note I9220 i717 -Black: Cell Phones & Accessories
    The GPS tracking on the Note 2 is fantastic. I use Nike+ to track my running mileage, and it works great.
    Thanked by:
  8. #8
    Default
    Quote Originally Posted by DAS View Post
    DAS
    Your posts are incredibly helpful..im 2 hours into the Note2. Overwhelmed- how do you close active apps on the device? It also fits great in my shir5 pocket. Its not a beast like everyone makes it out to be. Its Presidential
  9. #9
    Quote Originally Posted by ItsaRaid View Post
    DAS
    Thank you so much for your kind words. You close apps by long pressing on the home button. There you will see all your recent apps. To close them you just swipe them to the right or left and they will disappear and close.
    Sent from my GT-N8013 using Android Central Forums
  10. #10
    Chris5626's Avatar
    Posts
    Global Posts
    35 Global Posts
    Personally I find the device very easy to pocket.
    Although the Note 2 is a big phone it is not a particularly big object, my wallet for example is far more noticeable in my pocket and a tighter fit.
    The device isn't massively wider than most phones on the market and is very thin, most of the added size is in the height of the device but most pockets are generally quite tall (well mine are any way) so the extra size of the Note 2 versus a regular phone isn't an issue. If the phone were wider or thicker then I could see it starting to cause issues but I think Samsung did their research when it came to making sure the device was a large phone but not too large an object.
    The phone is also very lightweight, after a few minutes of putting it in my pocket I completely forgot it was there even when having it in my suit trouser pockets and sitting at a desk where I almost expected the thing would go straight through my pocket or leave me unable to bend my legs lol.
    Obviously it will depend on the size and shape of your pockets but I really haven't had a single issue with my Note 2 and pockets and I would expect that to be true for the vast majority of people. It might be worth checking at your local retailer to see if they have a display or even dummy phone that you can try in your pocket, I was lucky that the store I was in had a Samsung rep who had a Note 2 himself and let me try it which was very generous considering at the time I was looking at buying an S3 and doubly generous considering the rep doesn't work at the store and had literally nothing to gain by getting me to buy the product.
  11. #11
    When I got my note 2 I was a little worried about size as my old I phoned 4 was quite small.
    After a couple of weeks I find it far more usable than the I phoned and the screen is the right size when I need to browse the net.
    I never really notice it in my shirt pocket even in its leather case.
    Sent from my GT-N7100 using Tapatalk 2
  12. #12
    I'd say for a front pants pocket the note 1 is a little big. My only problems is its a tad bit to wide. And I wish it had the whole edge to edge display so we could get a 5-5.5 screen in a smaller body. When I pick up my old gnex it feels tiny compared to the note. Almost like when I went from the iPhone to the gnex
    Sent from my SAMSUNG-SGH-I717 using Android Central Forums
  13. #13
    CTthatdude's Avatar
    Posts
    Global Posts
    31 Global Posts
    so far im using my back pocket for this
  14. #14
    Get jeans with big pockets and you should be fine.
  15. #15
    tcapote's Avatar
    Geek Freak
    Posts
    Front pocket in regular jeans works fine for me, no issues. It is bigger of course, no no issues unless you wear skinny jeans (I don't). I use a TPU Cruzerlite Androidified case (clear), no problems getting in and out of my front pocket.
    There is no place like 127.0.0.1
  16. #16
    It is pocket-able but not very pocket friendly in MY opinion. I dont use it in the back pocket because I'll end up sitting on it. I carry it my front pocket but it doe bulge because i wear slimmer jeans. By no means do i wear skinny jeans but i do like my jeans fitted. It is definitely noticeable if youre looking at yourself in the mirror or walking. When you sit down it becomes a tad bit more problematic to remove. I mean its not THAT bad but it can be inconvenient at time.
  1. What is the hole on the top right of the battery cover?
    By HunterOrHunted in forum Verizon Galaxy Nexus
    Last Post: 12-27-2011, 03:39 PM
  2. What is the model number of the replacement battery for this phon
    By mojo rising in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-21-2011, 12:08 AM
  3. What is the best sd card to use on the sensation out of the follo
    By monstermav1 in forum T-Mobile HTC Sensation
    Last Post: 07-28-2011, 12:30 PM
  4. So what is everyone getting rid of to get the Thunderbolt?
    By coreymcl in forum Verizon HTC Thunderbolt
    Last Post: 04-12-2011, 09:45 PM
  5. Replies: 8
    Last Post: 03-07-2011, 10:26 PM
