Results 1 to 5 of 5
    Default How do I fix Maps using up my battery?
    Today was the only time I actually used Maps at more than just a glance, and it is now showing as using 25% of my battery. I did follow advice on shutting off Latitude, but it's still showing as using my battery by at least 1/4. Any help?
    sidenote: I do have Google Now enabled, and in my experience, it doesn't drain my battery (well, negligibly).
    I'll have an Ice Cream Sandwich with Jelly Beans on the side. Oh, and can I get a slice of Key Lime Pie?
  2. #2
    vr002sh's Avatar
    Posts
    Global Posts
    183 Global Posts
    Default Re: How do I fix Maps using up my battery?
    I had the same issue. I just forced quit Maps and that did it (until i use the map again, then i have to force quit it again). Seems like Google needs to look at this, this is the 2nd phone i have had the issue with.
  3. #3
    pkskier1's Avatar
    Posts
    Global Posts
    21 Global Posts
    I found that if you use the back button maps shuts down. Just using the home button maps will still be on in the back ground
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
  4. #4
    If you are using navigation make sure you do menu and exit navigation, otherwise that will run in the background (as designed). Haven't experienced that with maps though.
  5. #5
    brava27's Avatar
    Posts
    Global Posts
    567 Global Posts
    Yes, after buying the note 2 I cannot afford a car for google maps. I have to use my bicycle.
  1. Replies: 11
    Last Post: 09-13-2011, 05:00 PM
  2. Maps app using up my battery. Can't fix.
    By pudding 82 in forum Droid Bionic
    Last Post: 09-09-2011, 09:22 PM
  3. My SD card is read only - how do I fix this?
    By The Miz in forum HTC EVO 4G
    Last Post: 04-24-2011, 08:41 AM
  4. how do I fix my phone?
    By gizzyman in forum Motorola Droid X
    Last Post: 04-13-2011, 01:22 PM
  5. [Q] How do I fix my phone? System recovery, help!
    By lolreconlol in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 10-27-2010, 01:53 PM
