I'm not having good luck with the quick glance motion function. I've noticed it doesn't work at all with a case on. Anyone else notice this?
I'm using a generic plastic case. It does not cover the sensors although the spigen screen protector covers the lower part ever so slightly
Put phone on a flat surface, wait til screen turn off, put your hand covering sensors and youll get it
I've noticed that it only seems to work when the phone is NOT plugged into the charger. Kind of annoying since I keep it charging at night and thats the time I'm most likely to use the feature =-(
