Results 1 to 24 of 24
- 11-22-2012, 10:35 PM
Thread Author #1
So where can we get the genuine OEM SN2 wall chargers / car chargers?
Seems like every aftermarket charger is aimed toward crapple and ramps down the amperage. All of my 2.0 amp chargers are useless as I just switched from the iphone. I cannot find the one that came with the GN2 (the white eta-u90jwe) anywhere.
What are the proven 2A 5V chargers that everyone is using? - 11-22-2012, 10:56 PM #2
- 11-23-2012, 06:50 AM #3
- 11-24-2012, 10:52 AM
Thread Author #4
Re: So where can we get the genuine OEM SN2 wall chargers / car chargers?
This is it? I've read almost every forum everywhere and there isn't an off the shelf 2A or half decent android charger out there? Every charger or cable needs a mod...
- 11-24-2012, 11:17 AM #5
- 11-24-2012, 11:28 AM #6
I called Samsung to see if I could order one, the guy basically said no. It's not available. If its not on the web site, it's not available. So, I ended up ordering this one:
Amazon.com: PowerGen 1Amp Fast Micro USB Home and Travel for Motorola Droid Razr Maxx, HTC One X, Samsung Galaxy S3 and other Android Phones: Cell Phones & Accessories - 11-24-2012, 11:51 AM #7
- 11-24-2012, 12:53 PM #8
This won't help those who want something to take with them on trips, business, etc.... But for those of us who need something to use at home.............
You can click the photo to go to the website (it's thinkgeek.com) I have installed one of these at home and plan on buying a few more. They are quite handy. 2.1 amp max output per port. Various home improvement stores also have them but you have to make sure what the amperage is to make sure it will give you the juice you want. Really de-clutters our kitchen counter.Rocking the Galaxy Note 2. Rooted and De-Bloated. Take that VZW!! - 11-24-2012, 01:49 PM #9
- 11-24-2012, 05:45 PM
Thread Author #10
I got the att car charger as recommended. I will check it out later... Thank you very much.
- 11-24-2012, 05:50 PM
Thread Author #11
- 11-24-2012, 06:11 PM #12
Not OEM, but I picked this up - works great!
Amazon.com: New Trent Arcadia Rapiduo (1PC) 10W 5V/2A Dual Port high-speed USB car charger w/ Free Full Speed Micro-USB Charging Cable (IMP80C): Cell Phones & Accessories - 11-24-2012, 06:41 PM #13
I have a couple 2.1 amp chargers for iPad that aren't apple but they charge the note 2 and ipad just fine. Nothing special about the charger once it is rated up over 2A. I got several from monoprice.
- 11-24-2012, 08:06 PM #14
Max, I'm curious. How fast do they charge the phone as compared to the OEM cable? There are numerous threads on other forums that talk about how those Apple chargers might work but are limited to 500ma because of the way the Apple cables are set up. This is why you either have to short the USB cable in order to fool the charger/phone or get a dedicated "charge only" USB cable. Charging with a wall charger at home is one thing because you might charge overnight and not really care if it take 5 hours when it might only take 2.5 hrs with the OEM. The problem comes in the car with the Apple chargers because if you are running GPS and streaming music the charger may not keep up and will either remain flat or could even lose charge and your phone ends up dead. Any input on speed of charge for your charger? Thanks
Sent from my DROIDX using Tapatalk 2 - 11-25-2012, 05:36 PM #15
Couldn't say, never had a reason to charge the phone in the daytime. Right now looking at 11 hours 20 minutes and 64% charge. Worst day I have seen was a little over 17 hours with lots of use and wound up at 29% with the day done.
- 11-25-2012, 05:44 PM #16
- 11-25-2012, 06:03 PM #17
This phone by far has the best battery life of any smart phone I have ever had*, I turned off the battery percent in the titlebar and everything. Just don't worry about it.
If you are into games or something that is CPU heavy I'm sure that quad core can eat up some battery. Otherwise the power savings and big battery add up to being happy.
* except blackberry but IMO that isn't a smart phone. - 11-26-2012, 01:11 PM #18
Car Chargers, proper ones few and far between.
Here is a discussion about car chargers. I have the Qidmax (spelling) dual 2.1/5 watt charger listed on page 2 somewhere and it works great. I used the OEM charging cable that came with my phone and it would charge while using navigation and charging my wife's GS3 on the other port. I need to test it with a different charging/sync cable (another samsung OEM cable, but it came with the GS2 or GS3, can't remember which). - 11-26-2012, 02:22 PM
Thread Author #19
Here is an update to what I did..
After a ton of research, I'm not interested in modding anything.
The absolute best options are as follows:
Car charger: ATT branded charger that was listed in an earlier post in this thread.
Home / travel charger: the white one that comes with our phones that's listed on eBay. Miao20122miao is the seller.
Now I can move on with my life....
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2 - 11-26-2012, 10:01 PM #20
- 11-27-2012, 10:36 AM #21
Bah. Try to order the OEM charger from that Ebay seller and their paypal account isn't accepting payments. Argg. That would have been perfect. I need the 2 amp cable more then anything. My old microusb cable isn't charging 2 amps from my car charger unlike the oem cable that came with my phone.
I just need a cable and don't really want to try and short out pins myself. - 11-27-2012, 10:43 AM #22
- 11-27-2012, 11:00 AM #23
- 12-03-2012, 10:53 PM #24
Ok, I can confirm those cables linked in the 5th post DO charge at 2 amps! Got them today. Shorter then the one that comes with the phone but works great. Also, much more snug of a fit on the plug. My white cable that came with the phone was very loose and would fall out at the slightest bump.
Sent from my SPH-L900 using Tapatalk 2
Where can i get the Stock ROM?
By Brad48 in forum HTC myTouch 4GReplies: 16Last Post: 11-01-2011, 09:33 AM -
Where can i get the Android Central logo wallpaper
By kenmid in forum HTC EVO 4GReplies: 2Last Post: 12-22-2010, 07:37 PM -
where can i get the latest 2.2leak
By scotth45 in forum Motorola X Rooting, ROMs, and HacksReplies: 1Last Post: 09-22-2010, 01:15 AM -
Where can I get the "Droid!" sound effect in .wav format?
By whitenack in forum General Help and How ToReplies: 1Last Post: 06-09-2010, 09:23 PM -
Full retail? Those without an upgrade. Can we get the phone as well?
By JoshRH in forum HTC EVO 4GReplies: 6Last Post: 05-12-2010, 09:48 PM
Reply
