Results 1 to 2 of 2
    Default help with sd card can't make a folder and help putting rhapsody on it
    I have a sprint note 2 and I cannot make folders on the sd card. Everytime I try - it says creation failed. I am trying to put my rhapsody and amazon mp3 downloads on it. Can anyone tell me how to do this? Thanks.
  2. #2
    pkskier1's Avatar
    Posts
    Global Posts
    21 Global Posts
    Default Re: help with sd card can't make a folder and help putting rhapsody on it
    Are you using internal or external sd. My guess if its external did you format it first (if it was new). I found that going from gingerbread( att cappy) to jelly bean caused issues untill i formatted from gn2.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
  1. Help with SD Card showing Blank
    By wkufan92 in forum Sprint Epic 4G
    Last Post: 01-11-2012, 07:18 PM
  2. Need help with SD card not booting
    By kyjoe1 in forum Barnes & Noble Nook Color
    Last Post: 08-28-2011, 09:44 PM
  3. Problem with SD card and internal storage-pls help
    By fa2f in forum Misc. Android Tablets
    Last Post: 05-31-2011, 11:22 PM
  4. Help with SD card
    By kufta4 in forum General Help and How To
    Last Post: 03-23-2011, 09:16 AM
  5. help with sd card on htc hero sprint...
    By kkimble1986 in forum General Help and How To
    Last Post: 03-07-2011, 02:05 PM
