Results 1 to 5 of 5
    Default Galaxy Note II leather belt case
    Does any one know where I can buy a Leather case ( pouch ) that fits on your belt and has a ratchet clip for the Galaxy Note II SCH-R950 ?
    Jerry
  2. #2
    Default Re: Galaxy Note II leather belt case
    Ebay ur best bet. Post here what u find on there . Good luck
    Sent from my ADR6400L using Android Central Forums
  3. #3
    & are a couple ones I came across but are rather expensive. You could probably find some nice cheaper ones if you search on ebay.
  4. #4
    Check out this one below, it doesn't have a ratchet clip though. I have it and so far really like it, high quality leather with solid stitching. The phone is very snug in the pouch, so no worries about it falling out. My only complaint would be that it's too snug and takes a bit of effort to pull the phone out. I'm hoping it'll loosen up just a bit with some wear. Also, the clip is very strong.
    Monaco Vertical Pouch Type Leather Case with Belt Clip
  5. #5
    Quote Originally Posted by Synycalwon View Post
    Nice but Over over priced x10.
    Sent from my SCH-I6 05 using Android Central Forums
  1. Any Info on Best Buy Carrying the Galaxy Note II?
    By popologuy in forum Sprint Galaxy Note 2
    Last Post: 11-02-2012, 07:21 PM
  2. Galaxy Note II N7100 Previews/Reviews (Post them here)
    By Dachness in forum Samsung Galaxy Note 2
    Last Post: 10-06-2012, 02:31 AM
  3. will Galaxy Note II be more powerful than sIII?
    By funkylogik in forum Samsung Galaxy S3
    Last Post: 07-24-2012, 01:20 AM
  4. T-Mobile Galaxy S II with FREE Cases and Screen Protector
    By FreakyLocz14 in forum Sold / Archived Marketplace Threads
    Last Post: 12-10-2011, 11:06 AM
  5. Leather Belt Case?
    By jfenton in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-17-2011, 08:59 PM
