Headphones in and Notification Sound still coming through speakers
I was wondering if anyone else has noticed this "problem". I'm used to all my other phones setup so that when the headphone jack is plugged in all sound goes there.
I was sitting in the office and noticed that the notification seemed loud and when I took off my headphones noticed that was because the notification came through the speakers.
Yes my headphones were plugged in all the way.
Thanks for any information about this.
Re: Headphones in and Notification Sound still coming through speakers
Yes I experience that also worth my hands free device and want to know where the setting is to stop it.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
I don't think so??
Sent from my HTC One X+ using Android Central Forums
Quote:
I don't think so??
Do you know cyanogen-man??
It was kinda annoying when sitting in the library listening to some music and not realizing that everyone around you also hears the damn whistle notification and you are the ***** that didn't turn down the sound, when I had my headphones on and didn't even realize it! :-)
I noticed this as well....its annoying, but you can go into settings and turn off the sound for notifications in the sound section...
you can but it is unexpected behavior to me. usually when you have headphones or blue tooth all sound goes to that device by default. This is the first Samsung that I've had so they must just be different than everyone else!
That happens to me too. It happens on my S3 and Nexus too.
Sent from my Galaxy Note 2.
1 Attachment(s)
Press and hold the power\lock button to mute everything except the media sound after plugging in your headset. All of the sound settings will return to your previous settings when you unplug your headset.
This appears to be an Android bug and others are also using "SoundAbout" from the play store to work around this issue of automatically muting the external speaker when you plug in your headset.
[Only registered and activated users can see links. Click Here To Register...]
I wonder if this will work for bluetooth devices.
If you want notification to go through the headset, but not speakers, try SoundAbout in Google Play. Just un-check the "Notification to speaker" option.
