So, after owning the Note 2 for almost a month, I finally am trying to explore the stylus a bit. I like the idea of taking handwritten notes, but it seems it's still not quite fully "baked." I'll explain:
First off, it would be nice to have something better integrated with Evernote. I know you can sync S-Notes with Evernote, but it seems the note just gets added as a file attachment, and there's no way to actually open that attachment once it's in Evernote. So then what good is that?
Second, it would be nice to be able to set the default app that starts when you take the stylus out. Right now it's S-Memo or nothing. Heck, even being able to open a new S-Note would be better, as I'll explain below.
S-Note vs. S-Memo. It was a bit difficult understanding that there seem to be different content types within the note S-Note app. So you can do a full S-Note, but an S-Memo (which doesn't have an associated app, it's just a content type within S-Note) is similar but has a lot fewer capabilities. Specifically, you don't have the tools icon so you can't do andwriting recognition, shape recognition, etc. So what if I want to take out my pen and scribble a quick not but have it do handwriting recognition? Right now, I just have S-Memo open up. As far as I can tell, there is no way to then tell it to bring that memo into an S-Note. It's either an S-Note or S-Memo and they will never be transferrable.
Ultimately what I'd love is for the ability for it to bring up a new Evernote note and do handrwiting recognition within it. I realize you can install Skitch, but apparently it only does drawing, not handrwriting recognition. I suppose I could also share a note with Evernote, but it seems awfully manual. Optimally it should just sync as the S-Notes are supposed to - but sync into a format Evernote can display inline rather than as an attached file...
There seem to be numerous handwriting apps that come up when I search the app store, but I haven't started downloading and playing with any yet, so I thought I'd query folks here to see if anyone has played around with any of these apps to see what works best.
