1. sillyrabbitt123's Avatar
    So I loaded the Flash apk up and it was working with stock browser [still does] and it worked with dolphin beta [i updated dolhin beta] yesterday and now flash doesnt work with dolphin and i tried chrome too and that doesnt work. anyway to get flash sites to work with these browsers? what am i doing wrong?
    thanks
    12-07-2012 01:52 PM
  2. piizzadude's Avatar
    dolphin turns it off by default and will not let you turn it back on if you are on JB
    12-07-2012 01:55 PM
  3. sillyrabbitt123's Avatar
    not sure what you mean? dolphin turns it off by default and not let you turn it back on if you are on? if your on what? so i cannot have dolphin and flash now? if so what browser can handle flash.
    thanks
    12-07-2012 02:06 PM
  4. piizzadude's Avatar
    ok I am on Jellybean and have Dolphin and Flash installed.
    When I saw your post I went and looked. There is a setting in dolphin to enable Flash. When I ticked it to turn it on, it gave me a popup telling me that it causes Dolphin to crash and will not allow it to be enabled.
    So if you have Jellybean, you cannot have flash and dolphin together.
    Lastly, this is not Samsungs or Googles or dolphins fault. Adobe discontinued support awhile back
    12-07-2012 02:13 PM
  5. sillyrabbitt123's Avatar
    Thanks for the info. Damn. I knew I shoundt have updated dolphin beta. Now I dont have it and flash.
    Anyone got dolphin beta apk prior to their update?
    What other browsers will work with flash?
    Sent from my SCH-I605 using Android Central Forums
    12-07-2012 02:21 PM
  6. Mellimel22's Avatar
    Firefox, stock browser,naked,boat browser and plenty others pick one lol
    Sent from my Sprint Galaxy Nexus Rockin 4.2.1 using Tapatalk 2
    12-07-2012 02:25 PM
  7. piizzadude's Avatar
    If you do a search you can find it... I don't have it handy
    Oh and if you do find it, be sure to turn off auto updates
    Sent from my X-Band Modem... TY Genesis
    12-07-2012 02:36 PM
  8. sillyrabbitt123's Avatar
    thanks for the info. what other browsers have gestures? i make a few for certain sites and that why i use dolphin but withoout flash i might as well use stock except no gestures. any help is greatly appreciated
    12-07-2012 02:46 PM
  9. sillyrabbitt123's Avatar
    my new BESTIE maxthon browser seems to do it all. gestures, flash etc... pretty good. unfortunately bye bye dolphin though
    12-07-2012 03:55 PM
  10. sillyrabbitt123's Avatar
    I miss dolphin. Anyone have the apk for the version that works with flash? Thanks
    12-08-2012 04:01 PM
  11. wburleson's Avatar
    Which one do you have installed, i.e., Tablet or phone on your note2?
    12-08-2012 04:16 PM
  12. sillyrabbitt123's Avatar
    I had phone version. Should dl tablet?
    I am having problems with the phone version. I seemed to like it alot but I cannot stop a new tab from opening on every link I click on. Very annoying. If I could fix that then I would use maxthon. Just dont know how to. Messed with all rhe the settings to no avail.
    12-08-2012 07:17 PM
  1. Is it ZAGG or am I going crazy?
    By DizWhiz in forum HTC One X
    Last Post: 07-03-2012, 04:45 AM
  2. aaaaah! rom flashing questions(before i go crazy)
    By arlimes in forum General Help and How To
    Last Post: 05-27-2012, 09:53 PM
  3. screen and colors going crazy...help?!
    By sirk0rebreg in forum Verizon Fascinate
    Last Post: 11-29-2011, 08:27 PM
  4. Replies: 18
    Last Post: 09-29-2010, 10:58 AM
  5. Replies: 6
    Last Post: 06-10-2010, 11:58 PM
