I love the phone but need to make a quick decision whether to return it and get another.
I have had the Note 2 about a week, I enjoyed Android I changed form a Galaxy Nexus phone to the Note 2 I used these two apps on the Nexus and they worked fine, I have installed them on the Note 2 and neither work as they previously did on the Nexus - the pedometer doesn't count all the steps (way short) and the Sleep app doesn't register movements nor generate the correct graphs. I am ready to send the phone back so I need some helpful tests.
My guess is you will love the free apps any way!
https://forums.androidcentral.com/e...=jp.gr.java_conf.kino.walkroid&token=LTNhSWNq
https://forums.androidcentral.com/e...d=com.azumio.android.sleeptime&token=n2Ao9u5N
I would appreciate it if someone could run these two apps and let me know if it works for you as outlined and a simple night?s sleep with the phone face down will cover the Sleep app and walk 100 steps with the phone in your pocket and see if it counts the steps ok. My phone seems all over shop in the step counting.
The accelerometer may not be functioning properly as it was new I thought if it may be mechanical it may improve. I just walked 1.2 km and it shows 50 steps. At the half way point I changed the phones position and it was worse on the return walk!
I have calibrated the gyro and ran all the test apps and everything seems to work - they just may not be sensitive enough! Then I will contact the developer - by the way Sleep as Android works but is too hard on battery life IMO!
Both theses apps worked flawlessly on the Nexus and I used them both daily!
I firstly contacted the Sleep app developer but realised it could actually be a faulty phone.
I hope you can help as I don?t want to be stuck with a faulty phone if I can get another!
Thanks to those who do this for me!
