1. raffitou's Avatar
    I work in a place with 2 WIFI networks. One is my preferred connection which is secured with a password, then one which is Open. The secured WIFI is near my desk and the open is everywhere in the building. When I step away from my desk my phone switches to the Open network. When I come back it doesn't switch back to my preferred secured connection.
    Is there any way to assign a preferred WIFI connection so that when I'm near my desk it switches over automatically? The only other solution I've found is to "forget" the open network which I actually like to have access to when I'm in a dead cell connection area like the basement.
    Thanks
    12-11-2012 10:09 AM
  2. pool_shark's Avatar
    I haven't found a way to do it either.
    I have a dual band router at home. I prefer to connect to the 5, but the phone always chooses 2.4.
    12-11-2012 10:28 AM
  3. pete1118's Avatar
    My Linksys allows me to have a different SSID for the 5G band perhaps yours does as well? Check it out.
    Sent from my Transformer TF101 using Tapatalk 2
    12-12-2012 03:53 AM
  4. TheOtherBill's Avatar
    Same for my Netgear.
    FWIW: I thought I wanted to use 5, but I checked with WiFi Analyzer (great app, BTW) and the 2.4 was a much better signal. My connection on the 2.4 anywhere in the house or in the yard is a magnitude faster than I can get from my cable modem. That's way more than good enough.
    12-12-2012 10:09 AM
  5. raffitou's Avatar
    Found an app that does what I wanted.The app is Wifi Prioritizer. Tested it out and seems to be working. Its free.
    Sent from my SCH-I605 using Tapatalk 2
    12-14-2012 01:14 AM
  1. How-to: Syncing music over wifi from iTunes
    By Kyle Gibb in forum General Help and How To
    Last Post: 11-28-2011, 02:03 PM
  2. [HOW TO] SPRINT ACTIVATION BYPASS: WiFi ONLY
    By mmathai77 in forum Samsung Galaxy Tab
    Last Post: 08-20-2011, 09:21 PM
  3. How to assign ringtones to your contacts
    By kemo46 in forum Motorola Droid X
    Last Post: 12-18-2010, 04:48 AM
  4. how to find out what wifi im using
    By searles_400 in forum Motorola Droid X
    Last Post: 07-23-2010, 01:48 PM
  5. Droid - How to turn off Verizon Network Connection?
    By cward0625 in forum Motorola Droid
    Last Post: 11-09-2009, 12:11 PM
