Well my mount came in the mail and I unpacked it and messed around with it to get used to it. I'm finding that it doesn't fit my phone too comfortably when I have the Seidio ACTIVE case installed. Have to remove it to set it in nice and snug in the mount. This is ok, and I'm not too worried about this, but my concern is in how well it will stay suctioned to my windshield. I already had it fall over phone-face-first when testing it on my desk
thankfully the fall was only a foot or so and it doesn't appear to have sustained any noticeable damage, but it was certainly a heart-stopper for me as I baby my phone lol
Anyways the build quality seems nice on it, and I can't wait to get it setup in my car tonight for a test spin. Hopefully this freezing cold doesn't have an impact on how well it stays suctioned to the glass... not ready for round 2 of my phone taking a nose dive >: (
Will update later.
I like to use the app linked below. One thing I like is you can set for default mic off so you don't record cab sound. Also, when you play back on your phone you can see your speed via GPS.
https://forums.androidcentral.com/e...ps/details?id=com.dailyroads.v&token=KCzsr6UQ
Thanks I checked out that app and love it. Took a little to get it setup properly but now it does 100% exactly what I want. Basically, I wanted to be able to record video with MPH logging all in the background. This allows me to use
https://forums.androidcentral.com/e...m.nkahoang.screenstandby&hl=en&token=mnirNj1V to toggle my screens display. This helps avoid any pixel burn out from displaying the same exact layout on screen for minutes or even hours on end.
So thanks for the tip! Hopefully you can get some use out of that screen standby app to help your battery life and display life!
And now my update from last night.
This unit is great! It's 12 degrees outside all night long and it stayed stuck to my windshield no problem! Usually the cold presents a huge problem for these suction cup mounts but man that thing stayed glued to my windshield the whole night. I'm fairly confident now that it is nice and stable
I also took it for a test spin last night to see how well that Daily Roads Voyager app worked, and it is PERFECT! I have it all setup just the way I need it and in combination with 2 widgets for my screen standby app, I can toggle the background recording from my homescreen then hit my 1x1 screen off widget toggle and off I go driving with the screen off and recording in 1080p goodness!
Now I don't know for sure if this is just the app (Voyager) or the camera but as far as night time dash cam usage goes, the quality is a bit on the subpar side. I peaked at 14 frames per second on a 10 minute drive with only 7mbps bit rate instead of the camcorders usual 17mbps. Huge difference in quality but I believe I know why. Being so dark at night, it needs slower shutter speeds in order to get light into the camera. And the bit rate is dynamic, so it only raises for what it needs. Being that the majority of the image is black the bit rate was adjusted to lower to save space with a higher compression factor.
Anyways today I will be giving it another shot in daylight and I am expecting it to perform even better
This mount as Sh3ng posted in his video has absolutely no vibration whatsoever. I drive a Mazda 3 and the roads in my town in NJ are a mess this time of year. The cold and the ice really do a number on them. And believe me when I say there was 0 vibration in my dash cam, none at all. Totally impressed with this mount and would highly recommend it to any Galaxy Note 2 owner for sure.
