Results 1 to 8 of 8
    moralcode's Avatar
    Posts
    Global Posts
    97 Global Posts
    Default Power Saving mode consequences?
    Hey guys,
    My buddy and I both bought a note 2 in the same week and we've been comparing battery life day to day. He averages about 10% longer of battery life than me on the Power Saving mode all day.
    I'm not a huge gamer so my question is, are there any negative long term effects on the hardware or battery if constantly being in power Saving mode?
    I know that it lowers your cores and such to save power but would that cause and problems in the long term?
    Sent from my Note II on steroids
  2. #2
    I did it on my GS3 with no issues. Since it is built into the phone I can't imagine it would cause damage.
    Samsung Galaxy S4 - AT&T
    Samsung Galaxy Note 10.1 LTE - VZ
  3. #3
    Default Re: Power Saving mode consequences?
    I would guess Power Saving mode decreases heat, which is better for the CPU. But the CPU is durable. I don't think there's any practical gain in life of the CPU because you're using it less. If the CPU is good for 5 years at normal usage, and you're extending it to 10, what good is that when the Note 6 will be out by that time.
    I've killed CPU's in the past by overclocking it.
  4. #4
    Quote Originally Posted by Lucidmike View Post
    Moore's laws: Even what seems to be the most cutting edge valuable piece of hardware today will seem no more useful than a paper weight in two years time. (Or in the case of the note 2, a door stop)
    I would rather be finding out how to overclock it, but apparently it's already an overclocked sgs 3 chip...
    Sent from my SGH-T889 using Tapatalk 2
  5. #5
    Welcome aboard.
    Thanks for joining Android Central. Hopefully you'll find this place as insightful and helpful as I have.
    Cheers! :thumbup:
    Sent from my PG86100 using Xparent Green Tapatalk 2
  6. #6
    jdub1981's Avatar
    Posts
    ROM
    ATT SE 1.0
    Power savings mode scales back cpu frequency hence less power usage. I believe it turns off all apps that use data so no send and receive. This is all done while the phone is asleep by the way. I believe there is a little lag when the phone wakes back up because everything is turned backed on.
    I thing its a little over kill. This phone last forever and a day with everything turned on anyways. I dont use it.
    Sent via Tapatalk
  7. #7
    There's a few effects that Power Saving mode has on the device.
    1. CPU throttling. It will cap your CPU speed at I believe 1.1Ghz vs the max 1.6Ghz. This will have minimal impact on things like texting, web browsing and even light gaming. But heavy gaming and video recording etc, I would recommend not using it. It may adversely affect your experience.
    2. Display throttling. Your screens framerate will be cut in half to 30 frames per second. This reduces the power draw on the GPU by lowering the load, but it comes at the cost of things looking choppy. This option also reduces the brightness, even if you already are at minimum brightness, when you use the stock Internet app. Can be helpful since mostly all of the internet is a big white page with small text. White is your enemy with this phones screen technology as it costs the absolute most amount of power from your battery. Overall a good option that won't cause you to lose anything.
    3. Disable Haptic Feedback. This ones a no brainer, but does have a noticeable impact on battery life. Vibrate drains a good chunk of battery the more you use it.
    So overall it doesn't hurt anything to use this mode, but it can help save you some decent amount of power. Recommend using it for most situations for a casual user. If advanced, you probably already know when and when not to use it.
    Samsung Galaxy Note 2 on Verizon
    Jelly Beans Build 16 - Perseus 36.3
  8. #8
    I current am trying ds battery saver check it out in the market ...It shuts off all background apps,wifi and data and puts your phone into a deep sleep when your screen goes off and than re enables itself when the screen goes on so that helps but I currently have no clue how some guys are getting 8 to 9 hours with screen on and than still only at 50% use ..Crap if I ran my phone with screen on for 9 hours my phone would be hurting and definitely need to be recharged
  1. Replies: 10
    Last Post: 06-21-2012, 08:23 AM
  2. Power Saving Mode
    By Murphy5111 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 01-04-2012, 05:23 AM
  3. Does Power Saving Mode.. Save Power?
    By MAGiK9 in forum Samsung Galaxy S II Skyrocket
    Last Post: 12-08-2011, 06:51 PM
  4. Power-saving mode questions
    By harry_fine in forum General Help and How To
    Last Post: 11-23-2011, 09:17 AM
  5. Power save mode useless
    By michaeljc70 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 11-03-2011, 01:34 PM
