Anyone find a good mount for the note 2 for a bicycle. Any recommendation is greatly appreciated.
Sent from my SCH-I605 using Android Central Forums
Printable View
I've always been loathe to subject any of my expensive electronics to the vibrations presented by attaching them to my bike. I put my electronics in one of the three pockets at the rear of my various bike shirts--that way they aren't subject to intense vibration. Something to consider, IMO...
i hear you but i had this [Only registered and activated users can see links. Click Here To Register...] LOVED it but its too small to hold the note.
[Only registered and activated users can see links. Click Here To Register...] mount&cp=1&lp=5
I used it with the Note 2 and it worked fine. However, like Dave said, the vibrations will keep you worrying that the phone will fall. I am now using armband and the phone feels much secure. I bought the original Note armband because it's wider so I can use with case on.
I'm looking for this too. I've had bad ones, but I've also had a really good one for my evo. It's sometimes difficult to tell which you have until you hit one of those bottle jarring bumps. I'm looking forward to using my Note2 on a cross state ride.
I have had several communications with him at ibolt over this subject. They have a bike mount but not one that fits the note 2. I suggested to them that they should make the car dock into a bike mount because that car dock is the only thing I would trust,, it really holds the phone tight. She told me that was a great idea and she would speak to her boss about it but in the meantime if you took their bike mount and took the part of the car dock that the phone fits in to,, they are compatible. You can connect the car dock piece to the bike mount piece and make a really strong and secure dock.. That is what I am doing.
Note 2, it's true, ,size is everything!
This looks like a good one. My experience with bike mounts is most connect to bike with flimsy plastic. This alloy clamp has me sold. I may reconsider my initial plan for this one. Edit : yup,, nothing for the note 2 size.... My initial plan looks like what I am going to do.Quote:
Originally Posted by sillyrabbitt123 [Only registered and activated users can see links. Click Here To Register...]
