Results 1 to 9 of 9
    Default How big of an microSDXC card will fit?
    I haven't found anything that specifically says what is the largest recognizable size microSDXC card will fit in our Note2's? Everyone talks about the 32gb cards but I was wondering if a 64gb will work in it ? I'd hate to spend that money on a 64gb card only to find out it isn't recognized by the phone.
    Also, what's the difference between the SDHC and SDXC cards? is it just a capacity thing?----------never mind Wiki explained it to me...
    Thanks
  2. #2
    hopefulfarm's Avatar
    Posts
    Global Posts
    498 Global Posts
    ROM
    CM7 on the Nook Color
    Default Re: How big of an microSDXC card will fit?
    Yes . I have a 64gb card in my n2.
    Sent from my Samsung Galaxy Note II using Tapatalk
    Rockin' the Sprint Samsung Galaxy Note II !
    Thanked by:
    Thanks for confirming the XC's can be used. Did you jave to reformat it before you were able to use it or did our phone recognize the exFAT format?
    Sent from my SPH-L900 using Android Central Forums
    Thanks
    JTMcD.
    We sleep Peaceful in our beds because Rough Men stand ready in the night to visit violence upon those who would do us harm............George Orwell
    The object of life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting, 'Holy S@!t, What a Ride!!! -- Mavis Leyrer
  4. #4
    I have a 64gb sdxc as well. Sdhc is class 6 speed, sdxc is class 10 speed. That's the only difference
    sent from Galaxy Note 2
    Razr ics rooted
  5. #5
    Quote Originally Posted by johnmcd348 View Post
    Ex fat on sandisk u-1 sdxc confirmed for two weeks now no problems
    Also with 32gb class 4 sandisk cruzer exfat [mainly a phone drive]
    Sent from my SGH-T889
  6. #6
    Posts
    Global Posts
    498 Global Posts
    ROM
    Nope . Just put it in the phone and was good to go. 64gb has to be exfat. I did not have to format. SanDisk 64 XC from amazon.
    Thanks. Good to know so I can look at getting one of those instead of another 32gb SDHC card. I was looking at them since I can't get my other one to refprmat after using it in my wondows phone
    Thanks
    JTMcD.
  8. #8
    Dont newer windows os allow you to extend the size of fat32 above and beyond 32gb?
    Windows vista+
    Ive never tried it on a card tho this is my forst bigger than 32gb. I may give it a go on windows 8
    Im not sure. The Windows I was referring to was WindowsPhone. The HTC Arrive that I moved over from uses a MicroSD card for it's memory. It came with 16gb and I replaced it with a 32gb card. Only problem is that, when you install a new card, it locks the card to the phone and I can't seem to get it re formatted to reuse on something else now.
    Thanks
    JTMcD.
  1. How big of a deal is the game crashing bug?
    By jimbodan in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 01-12-2012, 09:44 PM
  2. How big of an issue is the lack of an SD card?
    By androidatic in forum Verizon Galaxy Nexus
    Last Post: 11-04-2011, 10:00 PM
  3. How to format an sd card(all ways possible)and how to partition?
    By tazman1963 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 08-16-2011, 06:16 PM
  4. How big of a concern is the power button?
    By MRW1215 in forum Verizon HTC Thunderbolt
    Last Post: 04-12-2011, 11:46 PM
  5. How Big of an SD Card
    By hockeyplayr in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 10-22-2010, 01:50 PM
