samsung galaxy note 2 wallpaper problem
hi all! can someone please help me. i cannot restore my default wallpaper (ripple wall) in my homescreen and lock screen. i recently used a photo in facebook, after that when i set back to the default wallpaper which is the ripple wall, it doesnt change and it still uses the photo in facebook. i tried changing the photo but it still doesnt go back to the default one.
please help.
thank you so much!!!!
Re: samsung galaxy note 2 wallpaper problem
will it delete all my files contacts applications etc?
Factory reset seems like overkill. I would worry.
Try just restarting your phone.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
Hey Op, just wondering if the restart fixed your issue. If not try deleting Facebook opening application settings and clearing your gallery cache and data. Then go to settings--display and choose your wallpaper there. Then reinstall Facebook.
Are you using a launcher lol. It is a simple setting issue.
