- 12-26-2012, 08:22 AM #26
- 12-26-2012, 10:32 AM #27
Re: Terrible, terrible battery life on the Note 2.
Some people believe the cost savings of leaving the phone off the charger at night are substantial.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums - 12-26-2012, 01:02 PM #28
I had, at one point 10-12 hours of batery life with 3G on all the while. But now, my battery heats up, and I get about 4 hours. I always kill apps on the back ground using the stock task manager.
I also use power saving mode. Doesn't help at all.
Do you guys think the battery calibrator apps in play store would help?
Sent from my GT-N7100 using Android Central Forums - 12-26-2012, 01:11 PM #29
- 12-26-2012, 01:40 PM #30
It boils down to improved battery health.You're wasting charge cycles because overnight the charger will stop supplying power once the phone reaches 100% so the battery will do it's usual trickling down while idle. The problem is then the charger kicks back in and lightly charges it back up to 100%. Doing this over and over again throughout an 8 hour night is not good for the health of the battery. I myself have noticed it having an impact on the following days battery life.
When I bring my phone down to about 20% and give it a full charge to 100%, with the phone off, that following charge cycle (100% to 20%) is incredibly potent and lasts me almost 3 days straight. Yet with the same usage, if I plug my phone in at like 50% and charge it to 100% overnight, not unplugging it while I sleep, then the following charge cycle is very weak and with the same or even less usage, I run out of battery twice as fast. I do have some screenshots to prove this as well, showing one charge with the same hours of screen on time making it almost 72 hours and hitting 30% battery. Yet on another try I had the screen on for a measly 3.5 hours and yet in less than 24 hours it dropped to the same 30%. Why? Because of the difference in how I charged it the previous night.Samsung Galaxy Note 2 on Verizon
Jelly Beans Build 16 - Perseus 36.3 - 12-26-2012, 03:02 PM #31
- 12-26-2012, 03:10 PM #32
- 12-26-2012, 03:48 PM #33
- 12-26-2012, 07:08 PM #34★★★★★
- 12-26-2012, 09:33 PM #35
Oh.. ok. Well. I stop all the social networking apps running in the background when i'm using 3G (no LTE or 4G in ny area), thats the H or H+ sign right?
I guess it still drains the battery if it switches from h or h+, am i right?
Sent from my GT-N7100 using Android Central Forums - 12-26-2012, 09:54 PM #36
Why is this happening.
I went from 100% to 97% in a span of 25minutes, and all i was doing was reading posts here in the forums! Help please. I wanna cry. This is so frustrating. :-(
Sent from my GT-N7100 using Android Central Forums - 12-26-2012, 11:47 PM #37
I feel bad for the OP. I havent cut my phone back on anything and it runs all day long with plenty to spare. I use quite a few apps as well. Seems like the only time my previous phone would drain like that is when my signal was very poor and it kept looking for signal all the time. I have had zero issues with my Note 2 battery. It has been a beast.
- 12-26-2012, 11:52 PM #38
- 12-27-2012, 01:39 AM #39
- 12-27-2012, 02:05 AM #40
This is correct. The screen is the number one battery drain you will ever experience with your phone, as far as using it goes. This is especially true with AMOLED screens that are on the max brightness viewing web pages with blank white backgrounds. That will kill your battery fast. Very fast. There really isn't any way of avoiding it except to turn the brightness down and if applicable use inverted coloring on web pages. It'll turn the blank white background to black and the black text to white. This will make a huge difference in battery consumption when browsing the web.
Jelly Beans Build 16 - Perseus 36.3 - 12-27-2012, 03:46 AM
Thread Author #41
Ok everyone, I'm quite tired researching this issue but I have found the problem and solution.
It's because of the high number of wake locks that's preventing the phone from going into deep sleep when at rest. That's whats draining out the battery so fast.
I also uninstalled the app lock app that was causing a high number of wake locks also. It seems that there is a bug in the OS that's preventing the phone from going into deep sleep mode in-order to conserve battery power.
The fix: Put the phone into airplane mode, reboot the phone, once it's booted up take it off airplane mode.
The results: AMAZING!!!
I ran a couple of tests to prove it.
At 4:00pm two days ago the phone was at 91% 3 hours later (No usage in between) 85%. For me that was a BIG difference. Before this type of reboot I was getting an average drop of roughly 6% per hour.
By doing this I was able to cut that down to a 2% drop per hour. Very nice indeed. The wake lock situation also looks much better as the PowerManagerService was able to kick in now.
Also I was even able to improve on that.
After I had enabled power-saving mode, at 5:00am the battery was at 63%. 10 hours later at 3:00pm, (Again no usage in-between), usually by now it would be dead but it was at 49%. That's 1.4% battery drain per hour. Much better.
I guess if it starts to drain fast again I'll just have to do that procedure again but at least I was able to find a fix and share it with you all. (I don't take credit for it
Hopefully this gets fixed in the next update.
Here's some screen shots showing the improvement after the reboot. Before I was getting 14h 33m on a full charge. Now it's 1 day, 7hours. That over twice an improvement in battery life. Yeah! I'm loving this phone now!
Let me know if this fixes your power drain issues too.
Thanks everyone for all your replies and suggestions. The android community is a very good one indeed!Last edited by Shirodx; 12-27-2012 at 04:06 AM.
Thanked by: - 12-27-2012, 04:00 AM
Thread Author #42
- 12-27-2012, 11:14 AM #43
I did the airplane mode trick and I have to say I have seen a vast improvement of my battery life as well. I do not know why or how it works but it does
- 12-27-2012, 11:18 AM #44
- 12-27-2012, 12:06 PM #45
- 12-27-2012, 12:13 PM #46
I meant turned airplane mode on, restarted phone, turned airplane mode off. Since I did that my battery life has improved. Maybe I wasn't clear in my post earlier.
- 12-27-2012, 08:37 PM #47
Here's my best battery life with heavy use. Tons of Facebooking, lots of Internet browsing and a couple hours of streaming video.
Almost 52 hours! To be fair this was with my screen turned all the way down when indoors and I only turned on bluetooth/gps when I actually used it. - 12-28-2012, 01:08 AM #48
Guys. Is it normal to drain 1% per minute when all I do is read books in my kindle app. No data. But cell coverage is on.
I guess not because before, it takes about a day and a half to get down to 15% now, just a few hours of rrading, anfd I'm done.
I did the airport trick. But still the same.
Sent from my GT-N7100 using Android Central Forums - 12-28-2012, 01:38 AM #49
- 12-30-2012, 06:59 PM #50
I've set the brightness to the lowest, but still same. Is there an app where the coverage will stay on H+?? Coz I think thats the culprit.
Also. I went hiking yesterday. Took too many photos, data is on all the time, uploaded photos to instagram and my battery life seemed to stay as is. It lasted me noon to midnight with practically raping it by capturing too many photos... i find it wierd coz at home, i only use it for reading ebooks and txting..
Battery Life on the Epic 4G
By Zephkiel in forum Sprint Epic 4GReplies: 9Last Post: 06-08-2011, 07:50 AM -
Battery Life on the R2D2 Droid
By AQuinn19 in forum Motorola Droid 2Replies: 4Last Post: 04-06-2011, 12:00 PM -
All this crying on the battery life on the first true 4G mobile
By Chilly818 in forum Thunderbolt AccessoriesReplies: 12Last Post: 04-04-2011, 12:59 PM -
By Chilly818 in forum Verizon HTC ThunderboltReplies: 11Last Post: 04-04-2011, 11:13 AM -
Battery Life on the Droid
By pstellato73 in forum Motorola DroidReplies: 8Last Post: 11-05-2010, 10:41 AM
Reply
