- 12-24-2012, 09:36 AM
Thread Author #1
Terrible, terrible battery life on the Note 2.
Hi everyone,
I've had my note for a week now and really like it, (Moved over from an iPhone4s).
BUT since I've had it the battery life has been so bad I can't believe that it's normal.
It barely lasts a day with only light surfing with out having to be charged.
I have the power saving feature turned on, wifi on, GPS off, active sync for all accounts turned off and the battery still drains fast.
An example, I had it fully charged to 100% at 1:30am, disconnected it from the charger, left it alone, the screen auto turned off. By 6:30am 5 hours later it was at 70%. That's crazy, something is going on.
Does anyone know of any monitoring apps that I can use to see what's going on while it's supposed to be in sleep mode.
I also have the golauncher installed, not sure if it's causing issues but the battery life was this bad even before I had installed that.
Also too, when I first got the phone, I didn't charge it for 24hours before first using it. How bad it that? Would that have had an effect on the battery? I know it mattered in the past, having to need to do a full charge first. Is that still needed to do? - 12-24-2012, 09:52 AM #2
Re: Terrible, terrible battery life on the Note 2.
Yes something is very wrong. I don't know off hand, but if you search battery in the forum thread or even go down the topic list a bit you will see numerous threads which are very helpful. Good luck.
Sent from my Unlocked Galaxy Note 2! - 12-24-2012, 09:58 AM #3
The not charging it part should be fine, there is no "memory" per say on the new li-on batteries. Their life span is based on charge cycles, so from 0-100% would be one cycle and each battery has a certain amount before it starts losing charge. I would suggest downloading an app called Better Battery Stats and letting it run while unplugged. This can tell you if your phone is getting to deep sleep, and if it's not, what is waking it up. The battery life on the note should be amazing. This is the first phone ive had since the flip phone days that can go for more than one day if not charged overnight
- 12-24-2012, 09:59 AM #4
Yes, something is wrong... but you already knew that. :-)
FWIW, I can make it almost 20 hours with moderate usage and a less-than-perfect LTE reception. Looking at battery statistics in the settings menu should give a good indication of the culprit(s). I've noticed that many of this year's Christmas-themed live wallpapers seem to be complete battery killers. I would probably start there. Good luck and let us know how it goes! - 12-24-2012, 10:23 AM #5★★★★★
- 12-24-2012, 10:42 AM #6
- 12-24-2012, 01:30 PM #7
Yes, please give us screenshots of your Battery page and then of the Screen on time page. You can find this under Settings -> Battery, and then by tapping the Screen tab in the list of items using your battery up. It's probably at the top of the list.
To take a screenshot press and hold Home and Power buttons at the same time until you see a white border flash around the edges and you hear a snapshot sound.
Then upload them both here so we can look at your battery usage, and screen on time.
I'm willing to be that what's killing your battery overnight is very poor signal quality. If this is the case the best solution is to put the phone into Airplane mode overnight and when you wake up you should see literally 0% battery loss. The downside is you won't be able to receive emergency calls.Samsung Galaxy Note 2 on Verizon
Jelly Beans Build 16 - Perseus 36.3 - 12-24-2012, 01:46 PM #8
Yes definitely not normal, I read all about the great battery life the Note 2 was suppose to have before I bought mine, really took that information with a grain of salt as for the last 5 Android based phone I have owned were some where between horrible and just acceptable. After owning this phone (Note 2) for the past 17 days I am amazed at the battery life, well exceeded my expectations. Yesterday, phone off charger at 7:30am 100% this morning at 10:30 am 21%. That's 27 hours with 4.5 hours screen on time, LTE and wifi mixed, 48 minutes of phone calls and a while lot of Internet time sitting in the mall waiting on the women to get done shopping
- 12-25-2012, 11:35 AM
Thread Author #9
- 12-25-2012, 12:30 PM
Thread Author #10
- 12-25-2012, 12:37 PM
Thread Author #11
The battery is draining very fast and that's with little usage during the day. The screen was not even on very much.
Here's an example.
Yesterday at around 2:00pm the battery was at 46%.
I put it into sleep mode and didn't use it at all afterwards.
I tried to turn it on at 10:00am this morning and the battery was dead.
That's crazy.
I am using the avast antivirus app on it but I don't think it's the issue. - 12-25-2012, 12:41 PM
Thread Author #12
Sorry, I'm not really sure how to interpret the colours.
Are the "blue" areas periods of activity?
Regarding the Mobile network signal, is the "gray" areas when it's poor, "green" when it's a good signal, and "yellow" when it's very poor and "black" when it's off or no signal?. - 12-25-2012, 12:46 PM
Thread Author #13
- 12-25-2012, 12:58 PM #14
Your screen was on two hours and you are at over 14 hours usage. You are charging and at 98%. For the note 2, that isn't good. However, you can post screen shots without charging, and post the applications useage screen shot. Poor network signals will zap any device. I would kill your data in poor signal areas and that should get you back to 24 hour plus days.
★★★★★ - 12-25-2012, 01:07 PM
Thread Author #15
- 12-25-2012, 01:15 PM #16
- 12-25-2012, 02:08 PM
Thread Author #17
- 12-25-2012, 03:19 PM #18
- 12-25-2012, 04:19 PM #19Samsung Note 2 and Nexus 7
- 12-25-2012, 06:13 PM
Thread Author #20
- 12-25-2012, 06:20 PM #21
You're used to an iPhone. This is Android. If you just took the phone out of the box and are using it as-is, it probably has a tacky animated wallpaper running, absolutely every stupid battery wasting feature enabled and 46 services running in the background. Most Android devices take a little tweaking out if the box to prepare them for use by a normal person. Try turning some stuff off.
- 12-25-2012, 06:27 PM
Thread Author #22
From a 100% charge at 2pm today, with practically no usage, at 7:18pm it's down to 73%. That's almost a 6% battery drain per hour. That can't be good.
By using better battery stats how can I tell if it's going into sleep or not. - 12-26-2012, 12:13 AM #23
How did you get that lucky with yours? That's incredible! I wish the battery makers could make as big advances as do the makers of other parts. Here’s a phone that would be ideal for my large graphics files (I’m a designer in New York) but when you’re talking 64GB, even on AT&T’s 4GLTE things don’t move fast enough that the battery doesn’t get drained quickly.
- 12-26-2012, 12:20 AM #24
OP you've got some serious wake lock issues. Seeing RIL as the top wakelock culprit I want you to try something, and I know this doesn't sound good but please try it. Tonight, if you can, put your phone into airplane mode but leave Wifi on and connected so you get data. If you wake up and experience minimal battery drain at best then I'm chalking it up to crappy signal quality and your phone having to wake up and push more power to the radio to keep you connected.
Jelly Beans Build 16 - Perseus 36.3 - 12-26-2012, 12:36 AM #25
guys i have same issue too
i have charged my note II (full at 12.30 am), and i put it and go to sleep
but when i wake up (6.30 am), the battery was at 37%
when i checked the battery usage, 94% on screen
how to solve this pls help =(
Battery Life on the Epic 4G
By Zephkiel in forum Sprint Epic 4GReplies: 9Last Post: 06-08-2011, 07:50 AM -
Battery Life on the R2D2 Droid
By AQuinn19 in forum Motorola Droid 2Replies: 4Last Post: 04-06-2011, 12:00 PM -
All this crying on the battery life on the first true 4G mobile
By Chilly818 in forum Thunderbolt AccessoriesReplies: 12Last Post: 04-04-2011, 12:59 PM -
By Chilly818 in forum Verizon HTC ThunderboltReplies: 11Last Post: 04-04-2011, 11:13 AM -
Battery Life on the Droid
By pstellato73 in forum Motorola DroidReplies: 8Last Post: 11-05-2010, 10:41 AM
Reply
