Results 1 to 4 of 4
    Default Swift Key Flow on Note2
    Is anyone using SwiftKey Flow Beta on their GN2. If so, have there been any issues with it for you? Does it come with several keyboard formats for both portrait and Landscape modes?
    Also is the voice to text accessible from a assigned key, ( not like presently, you have to access it each time )
    Any other input would be appreciated.
    Thank you in advance
  2. #2
    MannyZ28's Avatar
    Posts
    Global Posts
    4,624 Global Posts
    Carrier
    Stock
    Default Re: Swift Key Flow on Note2
    It crashed on me once, other than that I had zero issues with it. It has the same microphone button as the regular Swiftkey does. It is located to the left of the space bar and you long press it to access it. Yes it does have portrait and landscape layouts, just like the regular Swiftkey.
    I am pretty impressed by how good the flow part of it works. I am currently using the paid version of Swiftkey again since I like the new Berry theme, but I can't wait before Flow gets integrated into the final version. I am hoping for some more themes as well. Wish they would add a number row to it as well.
  3. #3
    Are they going to integrate flow into the normal swiftkey3? I bought that also but now using flow. I thought they might just come out with an entire different line. Anyway, I wish the microphone is one press instead of long press, but it is still way better than the stock keyboard of long press + pick. I could actually do without the "." and use that for ",", so the microphone could be one press. I always do double space for period.
  4. #4
    Xopher's Avatar
    Posts
    Global Posts
    4,732 Global Posts
    Carrier
    All Stock
    If I remember correctly, Samsung licensed SwiftKey for the text prediction and swiping features. Depending on your version of the Note 2, the swiping function is labeled SwiftKey Flow in the Samsung keyboard settings.
    It's not the same version as the SwiftKey Flow beta, but it should be taking advantage of some of the same features.
  1. Swift Key Flow on Note2
    By ItsaRaid in forum AT&T Galaxy Note 2
    Last Post: 01-03-2013, 12:22 PM
  2. Swift key tablet version available
    By E_man in forum Barnes & Noble Nook Color
    Last Post: 03-22-2011, 01:26 PM
  3. Does Swift key work on Epic 4g
    By marisdaman in forum Sprint Epic 4G
    Last Post: 09-23-2010, 02:40 PM
  4. Search key pressing on its own
    By Wakefulpanda in forum AT&T Captivate
    Last Post: 08-30-2010, 09:09 AM
  5. what do you guys think of swift key?
    By oasis9389 in forum HTC EVO 4G
    Last Post: 07-14-2010, 02:39 PM
