1. sonyscaria's Avatar
    Is there any option to auto disable/enable wifi/data connection on Galaxy Note 2 ? I just dont want to run data while at sleep. I am looking for built in option that third party applications
    12-31-2012 11:27 AM
  2. PsYcHoNeWb's Avatar
    I do not believe that there are any built in options that will auto turn on/off WiFi/data service built into your device. I know you can use the toggles up top easy enough but aside from that I do not believe that there is any on-board options. You may need to download something like Tasker.
    12-31-2012 11:47 AM
  1. Lost 3g connectivity on galaxy s3 after factory data reset?
    By manu51uk in forum Samsung Galaxy S3
    Last Post: 10-05-2012, 11:28 AM
  2. Tablet Data Plan on Galaxy S2
    By TheRealZero in forum Software Development and Hacking
    Last Post: 02-25-2012, 05:45 PM
  3. No mobile data connection on thunderbolt. Wife's incredible working fine.
    By RubberToRoad in forum Verizon HTC Thunderbolt
    Last Post: 08-06-2011, 12:38 AM
  4. No Data Plan on Galaxy sII
    By brotherjoe in forum Samsung Galaxy S II
    Last Post: 07-11-2011, 12:45 PM
  5. No Data Connection on CM 6.1.1
    By jnl813 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 01-13-2011, 11:53 AM
