I found a bunch of 32gb mini sd cards on Newegg for around the $20 mark of different brands, some I have never heard of before. Is there that much of a difference in them?
Sent from my AT&T Samsung Galaxy Note II on Straight Talk
Printable View
Stick with brand names. Not that they are better, but sometimes they have some better return policies and warranties if needed.
I usually buy Samsung or SanDisk. I have bought other lesser known brands and they functioned fine, but just a matter of personal preference.
They are probably all made in the same factory anyway.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
Check the class of the card. For shooting and storing video you need a Class 10 I believe. Yes there are lots of differences between a good card and a bad one. Check the read & write speeds on each.Quote:
Originally Posted by rexxcastle [Only registered and activated users can see links. Click Here To Register...]
Also, the longevity of the cards can differ.
