Results 1 to 3 of 3
    Default Is there a huge difference between SD cards?
    I found a bunch of 32gb mini sd cards on Newegg for around the $20 mark of different brands, some I have never heard of before. Is there that much of a difference in them?
    Sent from my AT&T Samsung Galaxy Note II on Straight Talk
  2. #2
    GMJeff's Avatar
    Posts
    Global Posts
    966 Global Posts
    Default Re: Is there a huge difference between SD cards?
    Stick with brand names. Not that they are better, but sometimes they have some better return policies and warranties if needed.
    I usually buy Samsung or SanDisk. I have bought other lesser known brands and they functioned fine, but just a matter of personal preference.
    They are probably all made in the same factory anyway.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
  3. #3
    4fool's Avatar
    Posts
    Global Posts
    16 Global Posts
    Quote Originally Posted by rexxcastle View Post
    Check the class of the card. For shooting and storing video you need a Class 10 I believe. Yes there are lots of differences between a good card and a bad one. Check the read & write speeds on each.
    Also, the longevity of the cards can differ.
  1. Is there a real difference between KB1 and KB2?
    By TehNewGuy in forum AT&T Captivate
    Last Post: 01-05-2012, 03:01 AM
  2. Noticeable speed difference from SD card class?
    By cmags in forum LG Optimus S
    Last Post: 03-12-2011, 04:41 PM
  3. Splitting Music between SD card and phone?
    By groundkontrol in forum Verizon Droid Incredible
    Last Post: 07-15-2010, 09:03 AM
  4. Screen protectors.. is there really a difference?
    By frettfreak in forum EVO Accessories
    Last Post: 06-17-2010, 12:48 PM
  5. Replies: 4
    Last Post: 06-13-2010, 09:40 AM
