From Full Charge to 15% Battery, 14Hrs. Is That Good?
I had my Note 2 fully charged and got it down to 15% in battery, and I checked, it was 14 hrs and few minutes total used.
6 hrs. of that 14 was dead use, meaning I didn't use my Note 2 'cuz I was sleeping that night.
Is that a good battery result???
thanks.
Re: From Full Charge to 15% Battery, 14Hrs. Is That Good?
If the 8 hours were you using it then i'd say that's pretty good
pretty typical. the Note 2 is the longest lasting smartphone I've owned, by a mile--all without having to get a humongous extended battery. :)
Guess that really depends on how long the screen was on during that time. Ive gotten long hours with 5.5 hrs on screen time too. Right now I have been off the charger for 11hrs 32 min and my screen has been on for 2 hrs 27 min. It really depends on how you were using it and the settings you use. My screen brightness is sitting at about 60%
Alright cool. Just wanted to see where everyone is at in regards to battery consumption. Looks like mine is in the norm and no defects on my Note 2. So thanks guys/gals!
2 Attachment(s)
Mine is above average then! :thumbup::D[Only registered and activated users can see links. Click Here To Register...]
Sent from my Behemoth of a phone, the Galaxy Note 2 :D
Im at 27% after 14 hours....and that's with over 6hrs of voice calls. I have my emails set to manual push and I don't use the power save mode.
Here's mine with tons of use for the last 7 hours and quiet a bit of off and on use for the first 11 hours.[Only registered and activated users can see links. Click Here To Register...]
NOTErized!
Mine is 21 hrs on moderate use with wifi enabled and 3 hrs of voice calls. Still 35 percentage battery left
Sent from my GT-N7100 using Android Central Forums
Mine right now is at 21% left of the battery, I'm sitting at 1 day 2hrs off the charger with 48min call time and 4hr 52min on screen time. I have brightness set around 60% and I don't use power save nothing.
