1. dodong27's Avatar
    I had my Note 2 fully charged and got it down to 15% in battery, and I checked, it was 14 hrs and few minutes total used.
    6 hrs. of that 14 was dead use, meaning I didn't use my Note 2 'cuz I was sleeping that night.
    Is that a good battery result???
    thanks.
    01-04-2013 05:00 PM
  2. Thorin Oakenshield's Avatar
    If the 8 hours were you using it then i'd say that's pretty good
    01-04-2013 05:02 PM
  3. 1812dave's Avatar
    pretty typical. the Note 2 is the longest lasting smartphone I've owned, by a mile--all without having to get a humongous extended battery.
    01-04-2013 05:02 PM
  4. byrds8's Avatar
    Guess that really depends on how long the screen was on during that time. Ive gotten long hours with 5.5 hrs on screen time too. Right now I have been off the charger for 11hrs 32 min and my screen has been on for 2 hrs 27 min. It really depends on how you were using it and the settings you use. My screen brightness is sitting at about 60%
    01-04-2013 05:10 PM
  5. dodong27's Avatar
    Alright cool. Just wanted to see where everyone is at in regards to battery consumption. Looks like mine is in the norm and no defects on my Note 2. So thanks guys/gals!
    01-04-2013 06:46 PM
  6. SenseMonkey's Avatar
    Mine is above average then! :thumbup:Click image for larger version.
    Sent from my Behemoth of a phone, the Galaxy Note 2
    Attached Thumbnails From Full Charge to 15% Battery, 14Hrs. Is That Good?-uploadfromtaptalk1357356193091.jpg
    01-04-2013 09:23 PM
  7. MrTyC's Avatar
    Im at 27% after 14 hours....and that's with over 6hrs of voice calls. I have my emails set to manual push and I don't use the power save mode.
    01-04-2013 10:17 PM
  8. redman#AC's Avatar
    Here's mine with tons of use for the last 7 hours and quiet a bit of off and on use for the first 11 hours.
    NOTErized!
    01-04-2013 10:34 PM
  9. sonyscaria's Avatar
    Mine is 21 hrs on moderate use with wifi enabled and 3 hrs of voice calls. Still 35 percentage battery left
    Sent from my GT-N7100 using Android Central Forums
    01-05-2013 03:19 AM
  10. byrds8's Avatar
    Mine right now is at 21% left of the battery, I'm sitting at 1 day 2hrs off the charger with 48min call time and 4hr 52min on screen time. I have brightness set around 60% and I don't use power save nothing.
    01-05-2013 08:34 AM
  1. Apple has to start over here, is this good for us now, or just a delay?
    By rootbrain in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-06-2012, 01:44 PM
  2. 3g to wifi battery drain - is there an app to fix this?
    By LindaSB12 in forum Android Apps
    Last Post: 09-05-2012, 11:20 AM
  3. Pda net from my charge to xoom
    By digmydroidx in forum Motorola Xoom
    Last Post: 12-01-2011, 08:11 AM
  4. Replies: 62
    Last Post: 05-23-2011, 09:59 PM
  5. I think my battery life is as good or better than my old Incredible??
    By Droidian in forum Verizon HTC Thunderbolt
    Last Post: 03-28-2011, 12:10 AM
