Is There Any Way To get Rid Of That Slide Out Tray On The Side Of The Note 2?
PsychDoc
1,544
269
83
It obscures stuff we want to see on the main screen. And it's really pointless and redundant anyway. Anything in there is already on one home screen or another.
HELP
Long press the back button for about two seconds and it will go away. Long press the back button and will return whenever you need it.
HELP
You can also get rid of it under setting-display-multi window. This gets rid of it all the time until you check the box again.
Theres also a multi window toggle in the notification bar you can switch on and off. Well on the verizon one there is, not positive of the other variants.
Thank you all. It's so good to know that you experts are always around to ask for advice.
Much appreciated!
Ohhhhhh cool I never noticed this before.. Thanks
Its not annoying. It lets you run 2 apps at the same time side by side.
Sent from my GT-N5110 using Tapatalk
I wish if I had say YouTube open I can just slide another app onto it to get split screen but for me I have to have to start with a blank screen.
Sent from my SCH-I605 using Tapatalk
r3dpuk3
