Note 2: OTG cable + USB hub?
tetaganda
62
I'm trying to research but can't find the right answers if I can use an OTG and usb hub to connect a thumb drive and wireless dangle for logitech wireless keyboard-track pad combo.
I dont want to fry my phones motherboard but I'd like to be able to connect these two devices.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
Re: OTG cable + USB hub?
If it's a powered hub I'm leaning towards yes it will work. Logical reasoning behind that conclusion is that the smart dock from Samsung is essentially a powered 3 port USB 2.0 hub and it all goes through that single input micro USB port on our phone.
If it's not a powered hub, it probably won't work. But it likely won't do any damage either seeing as how its no different than running too many USB devices off a PC board. It just doesn't work, but the PC continues to function.
Thanks so much! I didn't know there's a Samsung dock that has multiple USBs. Searching for a deal now. :)
It worked! :)
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Hi..im using this OTG cable..1 and 4 gb pendrive works on my galaxy note 2...if they single connection only...mouse also works on my galaxy note 2...my galaxy note 2 is stock not rooting...
But I have a problem with 4 port usb hub...i have connect this 4 port usb hub with many devices....I connect with mouse, 1 gb pendrive and 4 gb pendrive...my galaxy note 2 only detect mouse...my mouse works in my galaxy note 2...but pendrive not display in my files....I have connect extra power at the 4 port usb hub using plug or powerbank or laptop...but neither works...I have download usb host controller and diagnostic apps...it display the 2 pendrive specification...means it detect but I cannot open or display in my files galaxy note 2....I have reset but cannot too...
2nd problem is my 500 gb WD hdd not display too...the light at hdd will on and it spinning...but not display on my galaxy note 2....I have use usb host controller and diagnostic apps...it detect and display my hdd but I cannot open...and it dont display in my files...
Hope anyone can help with this problem...
Sent from my GT-N7100 using Tapatalk 2
Yes it should be work.
I can connect my Galaxy S3 to my USB hub via my OTG cable. While connected it automatically recognized my Razer DeathAdder mouse, Logitech G11 keyboard, USB Thumdrive, and PS3 controller. It doesn't need a power supply but it will obviously drain power faster. I'm not sure but I think there's a way to charge it while also having full USB hub functionality. However I'm currently looking into this and haven't found a working solution.
I have settle my problem regarding to usb hub..today I buy new d-link usb hub...and now all devices working...:D
I can watch movies from my hdd...
When I use all devices...my battery drain little...
Could just get a smart dock. It has 3 usb plugs and hdmi out. Also come with a 2a charging wall wart. Does everything you guys are trying to do.
Yes it does everything but I actually want 4 usb but I could settle with 3. The major point is that hub cost about 4 times the amount of a hub.
I like to save as much $ as possible.
Hey, im new here but I made a 4 port usb hub attached to a usb cable myself recently....all ports work including with the pendrive and other stuff atached.....if the pen drive or any other device dosent show up, u need to download this app called usb otg helper....u need to be rooted for this..root at your own risk...then u need to open the app and mount and unmount and mount again...then the devices will be recognised.....this worked for me...hope it does for u too... heres a pic of my creation ;)
http://db.tt/nz7GoltO
The otg-usb hub im using saves space and has 4 working ports... and its cheap to make cuz all u need is a cheap 4 port usb hub and a cheap otg cable (they both actually need to be cheap ones because later u would have to match the colouring of thier wires, the more advanced and expensive ones will have a confusing buildup inside thier wires) I can show u how to make this urself if u want me to, or unless u get it already :p
External hard drives (HDD), pen/thumb/usb drives should be formatted for FAT32 instead of NTFS for use with USB OTG. Otherwise, you will need a third party app on the device and it has to be rooted to 'see' or open and access any files on the attached storage device. Check out Paragon exFAT or USB OTG Helper in the Play Store as previously mentioned.
slackingfred
