1. dougm1970's Avatar
    1. to my understanding touchwiz sits on top of stock jelly bean, so would nova or apex launcher sit on top of touchwiz sitting on top of jelly bean ?? 2. i have all my apps laid out in folders on the homescreens perfect....could i try another launcher and then go back to touchwiz and would everything be as i had it before, apps in correct folders ??
    2. i have an issue that is bugging me a lot....when i come out of an app, i mainly notice it when coming out of the stock camera app, where it takes a few seconds for the screen to 'draw' the icons...so its just blank screen for a few seconds....would changing launcher help with that ?...or is there anything else i could do.....i'm happy enough at the moment with touchwiz only for that.
    3. i hear cyronegen (spelling?) rom spoke about a lot (i'm a complete newbie to android)....and i hear about nightly and monthly builds.....can someone explain that to me please....do you HAVE to update every night with a nightly build ??
    01-12-2013 11:37 AM
  2. tirith's Avatar
    I can answer some of these... for cyanogen, you don't need to update daily, just on big fixes. I had cm7 on one of my old phones and kept a year old rom on it. Nightlys aren't really necessary, a lot of the time there is no change.
    For the "drawing icons" part... any way you can tell me how much ram is being used? I don't notice that issue. As far as other launchers, I haven't tried any on my note, but they worked fine on other phones, and when I would delete one, the stock ui would take back over as if I never used anything else...
    Sent from my SPH-L900 using Tapatalk 2
    01-12-2013 11:53 AM
  3. dougm1970's Avatar
    screenshot attached on ram
    thanks for the reply
    Sent from my GT-N7100 using Android Central Forums
    Attached Thumbnails questions and issues i need help with ?-uploadfromtaptalk1358013587916.jpg
    01-12-2013 12:00 PM
  4. jdub1981's Avatar
    Wow. You can clear the ram occasionally bro. It wont hurt anything.
    Sent via Tapatalk
    01-12-2013 02:47 PM
  5. Scott Kenyon's Avatar
    Nova and ADW are apps. Touchwiz is also an app. They all perform the same function. Launchers don't sit on top of each other, they just replace the app before.
    To answer your question in a more direct way, all the settings of Touchwiz will remain the way they are should you choose to go back.
    Sent from my SGH-I317 using Android Central Forums
    01-12-2013 03:18 PM
  6. Jennings Richmond's Avatar
    Change ROMs at your own risk. Using a different launcher will not change the functionality of the device much, but a ROM will. Namely a good chunk of your S Pen functionality will be gone. Touchwiz is built into the stock rom not only as a launcher, but as a hefty piece of the entire ui.
    Sent from my SCH-R950 using Tapatalk 2
    01-12-2013 04:04 PM
  7. dougm1970's Avatar
    i do clear my ram a lot....but it shoots back up to that quickly...is that not a normal reading ??.....i presumed some dr web anti-virus setting / service running.
    i put on nova tonight....wow...what an improvement, for me anyway....very slick and can have neater home pages...grids 4 x 6 are perfect.
    using lockerpro lockscreen for notifications....but it seems to have trouble working....sometimes it'll bypass it completely and go to the main home page....or sometimes the stock lock screen will show instead....then other times it does work
    thanks for the answers
    01-12-2013 07:10 PM
  8. tirith's Avatar
    That reading means something huge is running in the background. Go to application management and see what apps are running. They should give you cpu total and ram usage iirc...
    dougm1970 likes this.
    01-12-2013 09:55 PM
  9. dougm1970's Avatar
    in running apps / cached processes...if i stop an app it just comes back right away, even if the app hasnt been started manually....is there a setting for that?....on this list, expedia is a prime example...
    Attached Thumbnails questions and issues i need help with ?-uploadfromtaptalk1358070136393.jpg
    01-13-2013 03:42 AM
  10. DroidXcon's Avatar
    This is Android not windows or IOS memory works differently read this article Help! Linux ate my RAM!
    many apps share services so for example what your screen displays many audio players so if you clear them all from memory and something uses a media service you see all the apps sharing this seem open. But they are not running so it isnt dragging your phone down. The battery widget is going to open because its a widget if you have it on your home screen its going to keep opening .
    01-13-2013 04:05 AM
  11. tirith's Avatar
    Honestly, I'm using more ram than that and not noticing any issues...
    I currently have 412mb open.
    01-13-2013 05:43 AM
  12. dougm1970's Avatar
    thanks for that....got ya.....so, like a previous poster said, am i using too much memory...or is using a gig...gig and half..ok?
    01-13-2013 06:04 AM
  13. DroidXcon's Avatar
    That's fine. Im currently using 1.19gig
    From my Galaxy Note 2 via Tapatalk
    01-13-2013 06:12 AM
  14. Scott Kenyon's Avatar
    Android manages is own ram. I have never needed to manually manage it on any phone I've owned.
    01-13-2013 08:24 AM
  15. dougm1970's Avatar
    thank you all.
    01-13-2013 08:49 AM
  1. Replies: 1
    Last Post: 10-23-2012, 09:00 PM
  2. A few issues I need help with
    By steeve725 in forum Virgin Mobile Optimus Slider
    Last Post: 05-24-2012, 06:37 PM
  3. Two issues I need help with on VZ G Nex
    By Dr0me in forum Verizon Galaxy Nexus
    Last Post: 02-22-2012, 01:11 PM
  4. Need help with emailing on phone and outlookexpress
    By tmax1964 in forum Motorola Droid X
    Last Post: 08-05-2010, 09:10 PM
  5. Need help with texting issue after I updated to 2.1.
    By Boztris in forum HTC Droid Eris
    Last Post: 05-16-2010, 03:14 PM
