DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Results 1 to 11 of 11
    Question QUESTION about buying an unlocked International Note 2 - will it work on EITHER T-Mobile or AT&T?
    Hi,
    Ever since owning a mobile phone, I have been on either Sprint, or now, Verizon, so I have a noob question about GSM in general.
    I want to purchase a Note 2 outright, and then have the option to use either T-Mobile or AT&T on a month-to-month basis. I live in Louisville, KY and hear mixed reviews of either carrier's coverage here, so I want to have that freedom to switch and test out each.
    On eBay, I see phones with specs listed below. Can someone please confirm whether this would work on either carrier? I see it says LTE in the title, and curious if that means it would work on AT&T's new LTE which just turned on here in Louisville. Thanks in advance!
    SPECS:
    Samsung Galaxy Note 2 ll LTE N7105-16gb-White(Factory Unlocked /WorldWide Ready)
    Features: 3G Data Capable, 4G Data Capable
    Carrier: Unlocked
    Cellular Band: GSM 850/900/1800/1900
    MPN: N1705
  2. #2
    Default Re: QUESTION about buying an unlocked International Note 2 - will it work on EITHER T-Mobile or AT&T
    The LTE will not work on at&t network.
  3. #3
    I don't think N7105 has LTE. I think it only has HSPA+. It should work on both AT&T and Tmobile though, just no LTE. You could get an AT&T one and unlock it yourself following the instructions on one of the thread:
    Unlock your ATT Galaxy Note 2 for free!
    I don't know how much does AT&T sell the Note II without contract though.
    Thanks for the info!
    An additional follow-up question: if I were to get the AT&T version and unlock it, will it have T-Mo 3G bands too?
    Thanks!
  5. #5
    raziel's Avatar
    Posts
    Global Posts
    247 Global Posts
    You are better off getting the AT&T version and loading the international ROM to have LTE with ATT. And yes it will work with with T-mobile 3G. Unlocking the phone following that guide is super easy and takes less than 5 minutes
    Macbook Pro Retina 13" 2013 | iMac 27' 2011 | iPhone 5 32GB | HTC One 64GB Developer Edition
    follow me @louievtran on instagram!
    Quote Originally Posted by raziel View Post
    Ahh, therein lies a kicker for me. Part of the reason I am making the switch is that Verizon wants to screw me for $15/extra per month for the "luxury" of having access to Good For Enterprise (to see my work email). An an additional kicker: to use Good, your phone can't be rooted...! UGH...
    Hence, I will be stuck with the ROM that is on there.
    Curious if perhaps I'd rather just go with the International version in the first place, and not have AT&T's LTE. The bright side would be I wouldn't have any AT&T bloatware!
    For an International version, do updates just come from Samsung??
  7. #7
    raziel's Avatar
    Posts
    Global Posts
    247 Global Posts
    Default Re:QUESTION about buying an unlocked International Note 2 - will it work on EITHER T-Mobile or AT&T?
    Yes international version comes straight from Samsung. But why wait even for them? There is so much developer support. I have the international rom for att which is the same thing with lte without the bloat.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
  8. Thread Author  Thread Author    #8
    I've been a "Root and ROM" person ever since my first Android device years ago, but in this instance, I've got to stay un-rooted if I wish to have Good on my phone...
  9. #9
    Is that a Good limitation or your company's?
    I have Good, and was contemplating your exact scenario.
    Sent from my HTC One X using Tapatalk 2
  10. Thread Author  Thread Author    #10
    Default Re: QUESTION buying an unlocked International Note 2 - will it work on EITHER T-Mobile or AT&T?
    Unfortunately it's a Good limitation. If you're rooted, it will detect it and notify your IT Dept!
    I even tried un-rooting my phone, but residual files still reported my phone as rooted...
    Then I found out about the additional $15/mo charge, and it was all over for me. They don't charge that for iPhone on VZW, just Android. And they are they ONLY carrier to pull that crap...
    Thanked by:
  11. #11
    Ugh. Thanks for the tip.
  1. "Unlocked" galaxy note 2, will it work on Verizon?
    By Dark SSide in forum Samsung Galaxy Note 2
    Last Post: 01-02-2013, 11:21 AM
  2. Unlocked International Note won't turn on after freeze!
    By pnwAl in forum Samsung Galaxy Note
    Last Post: 07-31-2012, 12:15 AM
  3. Will an unlocked HTC Evo 4G LTE work on AT&T?
    By skyview05 in forum HTC EVO 4G LTE
    Last Post: 06-05-2012, 03:14 PM
  4. Can an unlocked Samsung Galaxy S II work on t-mobile?
    By amazingjay in forum Samsung Galaxy S II
    Last Post: 12-21-2011, 11:04 PM
  5. Replies: 6
    Last Post: 01-18-2011, 12:16 PM
