Results 1 to 3 of 3
    Default What is"My call sound settings"?
    Can't figure out what it does despite changing settings. Options are: off, soft, clear sound, optimize left or right
    Sent from Note 2
  2. #2
    Default Re: What is"My call sound settings"?
    I believe this setting is default "clear sound"..... if you use the option below "my call sound settings" : "personalize call sound", it runs a test to find the best setting for you. Depending on the outcome of the test, it gives you options to make a change to the setting. It shows a graph on wich ear hears better and you can change for optimization for the left or right ear. I dont think there is much of a change personally. I just leave it on the default "clear". Im assuming that somone with impaired hearing would benefit form this more than somone that doesnt have a hearing impairment....try the test and make a choice....or leave it default and loose nothing from your current setting....
    Thx. I tried the first 3 and find clear sounds best
    Sent from Note 2
  1. What is causing my CWM error? (SOLVED?)
    By iskor12 in forum AT&T Galaxy S II
    Last Post: 12-28-2016, 09:40 AM
  2. What is keeping my phone awake and eating my battery?!?
    By DirkBelig in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 12-18-2013, 09:44 PM
  3. What is the wifi-calling on E4GT?
    By taylormah in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-16-2011, 04:54 PM
  4. What is with my mp3s?
    By Sonic132 in forum General Help and How To
    Last Post: 06-03-2011, 07:36 PM
  5. What is draining my battery?
    By jherm04 in forum Motorola Xoom
    Last Post: 03-08-2011, 10:06 PM
