1. sterandroids's Avatar
    My Note 2 has gotten some scratches because of those plastic cases (damn those!) and it's really annoying the heck out of me. I was thinking if it would be a good idea to get a titanium grey coating/paint so i can apply some on the scratched area. Does anyone know the exact paint code of the color of the titanium grey and if anyone knows where i can get such color? (maybe in a car store or something?)
    01-26-2013 11:30 PM
  2. Thorin Oakenshield's Avatar
    is the back part scratched? you can just buy a replacement back cover from ebay or something
    01-27-2013 12:51 AM
  3. sterandroids's Avatar
    Not the back, its the side area where the the earphone jack is located. Its a small dot probably 1x1mm size but its bothering me lol
    Sent from my GT-N7100 using Android Central Forums
    01-27-2013 01:36 AM
  4. vNaK's Avatar
    tbh the touch up paint you use is going to stick out more than the dot you currently have. it is not going to match even if you had the same exact color from samsung it will still look off. probably best to leave it as is.
    I would think a hobby store or automotive store would be your best bet in color matching it. I did see some sort of magic marker at costco for automotive and suppose to blend it in with ease. dont remeber what it was called tho.
    01-27-2013 02:43 AM
  1. Replies: 19
    Last Post: 02-12-2013, 10:36 AM
  2. What is the hole on the top right of the battery cover?
    By HunterOrHunted in forum Verizon Galaxy Nexus
    Last Post: 12-27-2011, 03:39 PM
  3. What is the model number of the replacement battery for this phon
    By Starfinder in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-21-2011, 12:08 AM
  4. What is the best sd card to use on the sensation out of the follo
    By monstermav1 in forum T-Mobile HTC Sensation
    Last Post: 07-28-2011, 12:30 PM
  5. So what is everyone getting rid of to get the Thunderbolt?
    By coreymcl in forum Verizon HTC Thunderbolt
    Last Post: 04-12-2011, 09:45 PM
