Anyone drill a hole in their Samsung Flip Cover? (Over notification light)
How did it work out? What bit size did you use? How did you measure?
Re: Anyone drill a hole in their Samsung Flip Cover? (Over notification light)
Seriously drill a hole in a flip cover? I'm not condemning your idea but is that necessary? Maybe just get a open face case and then you can always see your notification light? Is there a specific reason you absolutely need a flip case? If someone answers this and you pull it off, I'd love to see the finished product. Good luck
My GS3 sleeps in the bed and I make my girlfriend sleep on the couch
Yes.... I like it. (other than it covers the notification light)
Ok well happy drilling :)
Op there were a couple ppl on the forum who did this, I cant be much of a help, look through cases and flip cover threads, hopefully they see ur thread n respond so y9u dnt have to lo9k
have you heard about the GN2, yea it's awesome (^-^)
