02-08-2013 02:50 PM
50 12
tools
  1. MHH779's Avatar
    Hi everyone..
    This question might have been already asked hundreds of times..
    My battery seems to be different to all of you..
    It only stays like 8 hours of phone using (social apps, whatsapp, some videos and some games)
    It gets from 100 to 15 in 8 hours of using
    That's was on stock ROM..
    Now I'm using CyanogenMod 10.1 which significally should make my battery life better since its very light and really don't have any of those useless features in stock ROM..
    My display has the most consumption of the battery of like 70% of the battery. And my brightness is usually 20%
    Note: sync, NFC, GPS, Bluetooth is usually off..
    And I'm using 2G the whole day.. Also note that WiFi is always on.
    So what's wrong? This badass phone that has 3100 mAh only holding for 8 hours? My stupid iPhone holds longer than it
    What do you think guys?
    02-02-2013 02:01 AM
  2. runamonk's Avatar
    I had a similar issue and it was because of Battery drain due to RILJ. (Solved!) - xda-developers. Check this setting. Although I suspect it would be off by default with Cyan.
    02-02-2013 05:26 AM
  3. MHH779's Avatar
    I have already tried that but my battery still drain sp fast
    Five minutes of use drain 1%
    And i only bought my phone like 1 month ago
    Elai012488 likes this.
    02-02-2013 04:30 PM
  4. msndrstood's Avatar
    You mentioned you are on 2G all day, what is your signal like?
    What?! ...I'm msndrstood.
    via Gnex
    02-02-2013 04:48 PM
  5. MHH779's Avatar
    Full bars.. It never gets less
    02-03-2013 08:58 AM
  6. Phoneguy108's Avatar
    Hi everyone..
    Are you on ATT?
    02-03-2013 01:01 PM
  7. nrm5110's Avatar
    Post pics of your battery graphs both of them. Also since you are rooted grab betterbatterystats from xda.
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
    02-03-2013 01:04 PM
  8. MHH779's Avatar
    Betterbatterystats is useless on note 2.. Non of its functions work..
    Having an 8 hours of "display" (from 100% to 1%) is good?
    (While being on 2G network full bars, sync , GPS, NFC, etc.. Are off)
    02-03-2013 02:03 PM
  9. jdub1981's Avatar
    8 hours of display on time is great. Most of the battery specs you see on here thst are 24 hours or more are 5-6 hours of screen time with lots of stand by and other actions taking place. My ipad 2 battery last 10 hours of screen on time and a week of standby
    Sent via Tapatalk
    02-03-2013 02:22 PM
  10. nrm5110's Avatar
    How is it useless it works when you set it up correctly. I call user error all it is is a monitor.
    02-03-2013 02:23 PM
  11. Phoneguy108's Avatar
    If you are on ATT uninstall the ATT Locker update. The ATT Locker is a battery draining bloat app.
    02-03-2013 02:30 PM
  12. nrm5110's Avatar
    I just checked I've personally seen dumps from note 2's so its definitely user error. Figure out what you're doing and post those battery graphs like I asked also trust me I'm no noob I've built ROMs this isn't my first rodeo with battery complaints son.
    02-03-2013 02:36 PM
  13. ItsaRaid's Avatar
    I would like your input please.Prior to the AT&T 4.1.2 update I had fabulous battery time and no issues. 2 nights prior to the 4.1.2 update in the evening I noticed red and gray arrows in the upper left netx to the att icon I opened the notification window and it stated " Connecting to DNR Server ". Samsung stated that ATT did a unannounced maintenace update prior to the 4.1.2 update.
    Since the update my batter performance changed substantially. The other thing I noticed is there are substaially more items in manage apps running post update than prior.
    Prior to the update, nothing was disabled, wifi was on all the time , it wS almost too good to believe (batt times)
    It seems to me it has to be what was changed (something), running in the background, browser, something is sucking juice.
    I have every Att app disabled except hot spots. I am also looking for a explanation to the h8story graphs in batt. The colors and hash marks on the network measurements and their meaning.
    Thank you
    02-03-2013 02:54 PM
  14. nrm5110's Avatar
    I need battery graphs and info from BBS.
    02-03-2013 03:08 PM
  15. ItsaRaid's Avatar
    Thank you
    Attached Thumbnails Battery Life..-screenshot_2012-12-08-22-10-27.png   Battery Life..-screenshot_2013-01-31-23-32-30.png
    02-03-2013 03:08 PM
  16. ItsaRaid's Avatar
    02-03-2013 03:14 PM
  17. nrm5110's Avatar
    I need the other graph too. Touch that little graph up top and screenshot those results.
    02-03-2013 03:15 PM
  18. ItsaRaid's Avatar
    If wifi is on...then there should be NO network signal on correct? I am guessing that its the wifi maintence att did that caused this.
    02-03-2013 03:17 PM
  19. nrm5110's Avatar
    You have wakelocks for one so some app is pulling your phone out of deep sleep during idle times causing higher than acceptable idle battery drain.
    As for signal I think that graph uses those colors as a means to determine strength of the signal because even when you're on WiFi you are still on the network just not for data.
    02-03-2013 03:22 PM
  20. nrm5110's Avatar
    Possibly browser or play store but I'm doubting it you need BBS.
    02-03-2013 03:28 PM
  21. ItsaRaid's Avatar
    Are you on att? Sgh 1317?
    - - - Updated - - -
    02-03-2013 04:19 PM
  22. ItsaRaid's Avatar
    My sorry abt the device...my eyes Re bothering me, I didnt see your device. The first graph I posted was pre upgrade, the others were post upgrade. I was told the att update thing was to correct a wifi issue, the 4.1.2 update changed the browser and added stuff to what is always running. I tried stopping or disabling samsung push. All that was offered was stop. I did that and it restarted itself within seconds.
    02-03-2013 05:03 PM
  23. Droid_Evo_8's Avatar
    This is on Jelly Beans Build 7 and this is what I'm getting on the average on STOCK battery. So it's not too bad. Maybe you should give Jelly Beans a try.
    02-03-2013 05:20 PM
  24. nrm5110's Avatar
    Hahaha lookout what a scam.
    02-03-2013 05:23 PM
  25. Droid_Evo_8's Avatar
    Hahaha, I know. Suprisingly, didn't eat my battery much so I'm not complaining. Hahaha
    02-03-2013 11:05 PM
50 12
  1. Improving Battery Life on Your Android Device
    By ERDude in forum HTC Hero
    Last Post: 09-07-2013, 12:03 AM
  2. Battery life terrible?
    By bilobi in forum T-Mobile G1
    Last Post: 08-09-2013, 10:57 AM
  3. Samsung Moment battery life
    By IIJBII in forum Samsung Moment
    Last Post: 03-21-2012, 08:48 PM
  4. battery life
    By kunak83 in forum Motorola Droid
    Last Post: 11-29-2009, 11:28 AM
  5. Anyone's Battery Life Getting BETTER?
    By chrislitzkow in forum Motorola Droid
    Last Post: 11-20-2009, 11:04 PM
