Results 1 to 14 of 14
    Default SD card problem on Note 2
    Hi there yesterday in the late evening, i heard that my N2 notified me for something, so i checked what it was, and it said that i had to go in to the settings, before i removed my SD card.
    the strange thing is that it was in my pocket all the time, with the battery case on, and a silicone cover over that again. so there is no way i accidentally released the SD card.
    Now the phone doesn't recognize the SD at all. says that there is nothing in the slot. I've tried to take it out and in, turn on and off the phone (even removed the battery), but still nothing.
    So i'm wondering if some1 know what to do/experienced something like this before? transcend 32gb class 4 microsdhc
  2. #2
    Default Re: SD card problem on note 2.
    try the card in another phone. try another card in your note. results should tell you if you have a bad phone. good luck.
    Quote Originally Posted by dave1812 View Post
    It is the SD card wich kinda sucks, since i bought it in november, and had just finished downloading almost 3000 songs from spotify ..
    So i'll buy a new one. Any suggest on wich kard? was thinking about buying on ebay, since it's so F**king expensive here in Norway..
  4. #4
    tirith's Avatar
    Resident Linux Fiend
    Posts
    Carrier
    Stock Touchwiz LJC 4.1.1
    SanDisk is a big name in sd cards, make good products. I'm still using an 8gb card I was given by a friend 3 years ago
    Swyped from my Galaxy Note II on the Now Network
  5. #5
    Quote Originally Posted by tirith View Post
    CAUTION!!!! There is a VERY WELL KNOWN issue with SanDisk cards and newer Samsung phones!!! Your card might not have failed if it was used in another phone... Apparently some compatibility issues with (especially) 32GB and 64GB SD, both Class 4 and 10 cards mostly from SanDisk cause random unmounts/re-mounts (and accompanying battery drains every time the device scans the media for errors); mine just acted up after two months of purchase. If you're lucky, you can still use the card in a computer to back up data, but it may end up entirely fried by the phone.
    Most posts I've read recommend Samsung cards (duh!) and A-Data (apparently, the innards are supplied by Sammy). It sucks? Yeah... But it's an issue with Note 2 and S3 phones right now. Again, mostly on SanDisk cards but there have been reports of other brands going kaput, especially 32GB cards. 16GB cards, however, don't seem to have this issue.
  6. #6
    tirith's Avatar
    Posts
    Carrier
    Quote Originally Posted by SpookDroid View Post
    Mine did go corrupt but I'm sure I was the culprit behind it.... just formatted it and saved all my data back to it... I have a folder on my hdd I sync my phone to weekly.
  7. #7
    CAUTION!!!! There is a VERY WELL KNOWN issue with SanDisk cards and newer Samsung phones!!!.
    Link(s) please, to CREDIBLE sources of that problem.
  8. #8
    Dave, I could give you a bunch of links but doing a Google search will serve you better... There's even a SanDisk response somewhere I'll try to look it up... But the problem is real, is mostly on 32GB and up SanDisk and Sammy is NOT recognizing the issue
  9. #9
    TJB
    TJB is offline
    TJB's Avatar
    Posts
    Global Posts
    184 Global Posts
    I had the same problem on my Note 2. Scan Disk replaced the 32gb card after I told them I was using it on my Note 2. They new about the problem. I sent the old one back and they sent me a new one. Took about a week.
  10. #10
    See? I'm not making it up :P
    TJB, how was the process to get a return? I fear it won't be as easy for me as I'm not in the US And I KNOW the retailer will try to weasel out of honoring the warranty since the card can still be read in a computer, I'll just not risk my phone again by putting it back in.
    BTW, did you notice any werid behavior in your phone while charging when the issue started? I noticed that mine started acting up at the same time the SD card began to get unmounted: first, plugging it in to charge would suddenly say I was plugging in a dock, which I wasn't... then, I noticed the red LED charging indicator's brightness would randomly fluctuate while charging... I fear the SD card problem is also leading to stray currents within the phone or weird voltage levels and it might, eventually, damage more than just the card.
  11. #11
    lgwhitlock's Avatar
    Posts
    Global Posts
    5 Global Posts
    I was having issues with my 64GB SD card and then I remembered the FAT specification said there was a limit on the number of files that could exist in the root directory of a drive. I moved the files from the root directory to a second directory and now mine is happy and starts up without issue. In fact it's the first time in a long time it started up without a minute or more scan of the 64GB SD card before mounting it. So for those of you having issues give this a try; it just might fix it for you too. Good luck.
    Leland
  12. #12
    Same problem as OP on Note 3 with a new Lexar 32gb SDHC
    Worked fine yesterday after migrating my files from old phone (copied from old card to computer then to new card). Today I received a notification about an unauthorized access to system:
    "An application has been forced to stop for an unauthorized attempt to access system in your device"
    I couldn't tell which app was responsible; phone appeared to be working okay.
    A few hours later SD card showing it wasn't mounted - trying reboot, reinsert, etc... nothing worked I could see all items when read in computer. I compared the content I copied to the card originally. Noticed 2 extra folders which the phone presumably added:
    Android and .android_secure (IIRC)
    Deleted these from card in computer. Reinserted in phone and it worked again.
    Phone has since re-added the Android folder, and SD is still working so far.
  13. #13
    tube517's Avatar
    Posts
    Carrier
    Decks Reloaded,RebelROM
    I keep getting a message that my sd card is damaged and it suggests to reformat. However, it still seems to be working fine. I have come across this issue in several forums so it is a known issue as posted above
  14. #14
    If you keep getting that message I STORNGLY suggest you either get a new card or stop using that one in your phone. A few reasons:
    1) It's a HUGE battery drain. Every time you get that message and the card unmounts and then remounts itself, the system scans it. The more files you have in it the more time the scan lasts. And this happens multiple times during the day, even when you don't see the message happening while your screen is off. With time, these unmounts will happen more often and your battery will take the toll.
    2) Your card is already failing. Don't risk losing important data like your vacation pictures or that 'Big Foot' photo you only snapped once or be cut off mid-video because your card decided to fail (and trust me, the part you thought you had already recorded will NOT be there). In time, even files that were already there will begin to show corruption.
    3) Your system will start lagging and behaving incorrectly. Some apps will store data on the SD card if available. When your card unmounts, this data becomes unavailable and more often than not, when it re-mounts, the apps don't see the data is back. This, of course, causes strange stuff and crashes. You'll be forced to reboot more often.
    Just a suggestion, but one that I can tell you from personal experience is very worth taking.
  1. Note 2 micro sd card problems
    By Kale Blossom in forum Verizon Galaxy Note 2
    Last Post: 02-17-2016, 01:41 AM
  2. SD card damged on mount with apps2sd
    By redbeardtheweird in forum HTC Hero
    Last Post: 10-11-2014, 05:47 AM
  3. SD card problems: incl reading on PC
    By tonylinde in forum Samsung Galaxy Note 2
    Last Post: 01-19-2013, 06:21 PM
  4. Updates to apps on SD card problem
    By cataylo6 in forum HTC EVO 4G
    Last Post: 02-18-2011, 08:18 PM
  5. Droid sd card problems?
    By azezial in forum Motorola Droid
    Last Post: 11-30-2009, 03:23 PM
