Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
  1. #26
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Default Re: Instructions on using DLNA? It doesn't work.
    Ive only had one router that was dd-wrt capable. Linksys model I think.
    Sent via Tapatalk
  2. #27
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jdub1981 View Post
    Upnp is enabled in your router webpage where its settings are stored.
    Eclipse you are correct, not all routers are the same any many are DOA or die just outside of warranty I have had many. Bittorrent eats cheap routers for breakfast it seems.
    Sent via Tapatalk
    So I should check my router, and it should have that webpage...
    I'll check when I get home.
    thanks to all of you guys for the help!
  3. #28
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Ok here are the 2 vids I made with the Ipad 2.
    Audio Streaming
    Video Streaming
  4. #29
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I did exactly what you did for the Video streaming and I keep getting this meassage:
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    Attached Thumbnails Attached Thumbnails Instructions on using DLNA? It doesn't work.-uploadfromtaptalk1360132074995.jpg
  5. #30
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I checked my PS3 settings, everything is enabled. I can stream Pics to my TV but not my Videos.. Argh!!!
  6. #31
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Unfortunately I could not get it to work with ps3 either. It might be a setting I have wrong. I dont know. Like I said before I really only use the ps3 for bluray.
    Sent via Tapatalk
  7. #32
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    Same here, I only use our PS3 for netflix and blu-ray...
    But to get my movies from my Note 2 to my Tv would be so awesome! But F@$K... this is irritating!!!
    - - - Updated - - -
    If you ever figured how to make it work on the PS3, please share!
    Thanks for all the help and video!
  8. #33
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Just found this with google. I dont know if it works, ill try it when I get home tonight.
    http://www.brorsoft.com/how-to/strea...-via-dlna.html
    Sent via Tapatalk
  9. #34
    SumthinNew's Avatar
    Posts
    Global Posts
    621 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can confirm that "Allshare" streaming from my Note II to my Samsung smart TV works for both videos and pics.
    Each time I enable the feature on my Note II, a pop screen would appear on my TV requesting to accept the connection.
    My hardware:
    Cisco DPC3825 Gateway modem/router combo provided from my ISP
    Samsung 8000 series with integrated wifi
  10. #35
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SumthinNew View Post
    My hardware:
    How does All Share work?
  11. #36
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    Cool I'll try it also when I get home...
    Let us know if yours works.
  12. #37
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Man... it didn't work... =(
  13. #38
    Areplat's Avatar
    Posts
    Global Posts
    63 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I know that there are several applications for Android which provide DLNA support for smartphone. What do you use?
  14. #39
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Areplat View Post
    I tried to stream my videos directly through my Note2 and even tried the sony dlna app, and I would still get the same message...
  15. #40
    brentj's Avatar
    Posts
    Global Posts
    281 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just got a new Panasonic TV which I linked in to my home WiFi. It has YouTube on it, and it gave an option to sync my phone with the TV YouTube app, which I did. That worked to let me find and start a YouTube video on my phone, which would then play on the TV. I did nothing else (not knowingly, anyway) to connect my phone to TV. I was very surprised later when I started playing music on my phone through the stock music player, and it came up automatically on the TV and through its sound system. I checked and this also worked with the stock video player, and with the stock photo gallery. I have no idea whether this is "dnla" (about which I know nothing) or some other connection method, but I was pleased to be able to show photos and videos on the big screen, and pump music through that sound system. Got lucky, I guess.
  16. #41
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by brentj View Post
    Ya my Sony tv also has YouTube app amd I can connect my youtube accnt from my Note2 to my tv, just like you. And I can also stream pics and music using the stock apps.
    But streaming videis directly from Note2 to my tv, some reason it won't work.
    When you stream your videos to your tv, do you stream it directly to your tv or do you go through a player, PS3 or Xbox???
  17. #42
    brentj's Avatar
    Posts
    Global Posts
    281 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, direct to TV.
    Edit to add: Got home and checked, it shows on my TV as a dnla connection. Not all of the .mp4 videos on my phone will play on my TV (I think I've created or converted them using a variety of software and settings over some years), but in that case the TV still gets the signal from my phone, shows the name of the video file, and gives a message "Cannot Read File."
  18. #43
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    I assume its because not all video file typed are created equal. Such as different bitrates and different audio codecs from within the video file.
    I still have not found one single video that I couldn't play through dlna and Xbox 360. Can't get the ps3 to play any vids though.
    Sent via Tapatalk
  19. #44
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    in PS3!!! Pissing me off!
  20. #45
    whatsitsname's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    dodong27
    On the PS3 you can only use the PS3 to remotely play videos from the Note 2 (ie you can browse the media files on the Note 2 and play them from a PS3 remote). You cannot use the Note 2 to directly play/control videos on the PS3. From your pic on post #29 it seems like thats what you are trying to do. From the pic I am almost positive that it is not the PS3 you are connected to. You are probably connected to your tv or a blu-ray player (that is connected to your home network). Both of these products would be able to play pictures easily but would not be able to play most or any digital video formats.
    Try this.
    Unplug your PS3. If you still see the "1" on the upper left corner of your Note 2 video player you will know that it is not the PS3 you are connected to.
  21. #46
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Have to tried plugging your phone into the ps3 usb ports.... Or you could try the super awesome xbox 360
    Sent via Tapatalk
  22. #47
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    That's no longer an option. All newer Samsung phones uses MTP protocols which is unrecognizable to all but computers. Boy I hate this protocol with a passion.
  23. #48
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    I did plug my Note2 into the ps3 usb port andnit doesn't recognize my Note2..?
  24. #49
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by whatsitsname View Post
    dodong27
    Try this.
    Cool, I will try this and see. I'll let you know...
  1. Replies: 8
    Last Post: 10-23-2011, 03:40 AM
  2. Why am i still using android! It doesn't even work!
    By bentor1996 in forum Verizon Droid Incredible
    Last Post: 07-08-2011, 01:35 AM
  3. Replies: 3
    Last Post: 06-22-2011, 11:29 PM
  4. Why are tablets 600px when they know it doesn't work well for web
    By potatoho in forum Misc. Android Tablets
    Last Post: 04-07-2011, 03:15 PM
  5. Appbrain wants to update my Flash (but it doesn't work)
    By ArchGoodwin in forum Market Help
    Last Post: 08-20-2010, 02:49 PM
