Page 1 of 2 12 LastLast
Results 1 to 25 of 49
    DirtMcGirt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Instructions on using DLNA? It doesn't work.
    I've got a fairly new Samsung TV and Xbox 360. Neither of which detect my phone. Is there a manual on how to get this to work? I enabled Nearby devices and shared everything out yet when I open a pic or video on my phone I don't have the option of streaming it elsewhere.
  2. #2
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Instructions on using DLNA? It doesn't work.
    I tried all that I can with this feature, and it only works with my Pics and not my videos.
    I have a Sony Bravia LED TV and PS3... I've enable everything on all devices and still nothing on Videos... frustrating...
    DirtMcGirt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dodong27 View Post
    Yea... that's what I'm sayin'. Then you have people saying it works, I don't get it. My TV worked fine over DLNA with my Verizon Thunderbolt using the 'Connected Media' app.
  4. #4
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    It does work. I did it this morning when I was getting ready for work.
    First the phone and the xbox must be on the same network cuz thats how dlna works. If your xbox isnt connected to a router it wont work.
    2. Once the xbox boots to the menu, go to your phone. Go into the stock music player and play a song. Now hit the menu button to the left of the hone button. Scroll through the menu and select scan for nearby devices. It should find it. Now back on the music player screen you should see a little computer icon looking icon at the top left. Tap that and will automatically connect to the xbox. At this point the xbox will change screens and the music will start playing.
    3. Once the initial connection is made you shouldnt need to do it in the future. So if you turn off the xbox and then back on your phone should automatically find it. Once again you must press the icon on the top left of the gn2 music player app.
    4. As far as video goes, this is thoroughly depending on quality of connection and router network speeds. My phone stored torrents play just fine with zero lag. However ONLY video formats supported by xbox will play.
    Sent via Tapatalk
    kris.richards likes this.
  5. #5
    kris.richards's Avatar
    Posts
    Global Posts
    273 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm guessing this doesn't work with Google Music?
  6. #6
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jdub1981 View Post
    Sent via Tapatalk
    What type of video formats is supported by PS3? and is there a way to change the format if it's different?
    Thanks!
  7. #7
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Quote Originally Posted by kris.richards View Post
    I dont know the answer to that question. I dont use google music. Stock music player is more than good enough for my needs
    Sent via Tapatalk
  8. #8
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Thanks!
    Im sure you could google the formats ps3 supports and find out faster than making a post. Yes all files can be converted. You find a program for your computer that converts from/to and download it. Typically open source software is good enough. To those that dont know open source means free and usually can be reprogrammed to do something different if you choose and have the experience in doing such.
    Sent via Tapatalk
  9. #9
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    Thanks man, I'm just sick of trying to figure this out... All that's left for me to do now is call Samsung and/or Sony.
  10. #10
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i have some movie files i got through utorrent and want to stream it on my tv... but... sigh...
  11. #11
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    I know xbox supports avi xvix divx files for video cuz thats the torrents I usually download. I have a ps3 but its ONLY used as a bluray player. I do not have a single game for it.
    Are you still having problems with dlna? I can tell you that the stock video player and the stock music player work. If the stock video player does not play the video then neither will the xbox most likely. Also just cuz the phone supports dlna that doesnt mean that all apps are supporting it. Try the stock apps not the ones labeled as google or samsung players but just plain stock. Get back to me and let me know how it went.
    Sent via Tapatalk
  12. #12
    Eclipse2K's Avatar
    Posts
    Global Posts
    5,970 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    Same here on the PS3. I rent games once in a while but its for movies. I too have not been able to get Xbox to work as DLNA either for some reason. My RAZR worked for minutes than disconnected. No idea why but DLNA has been an issue ever since I dumped my Thunderbolt.
    Sent from my Samsung Galaxy Note II using Tapatalk 2.
  13. #13
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    I will attempt to make a video with my crappy ipad 2 tonight on exactly how to do it. I will then put it on youtube.
    Hopefully it will be suffecient.
    Sent via Tapatalk
  14. #14
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Just thought of something else. It could be thst your ports arent forwarded correctly in the routers settings.
    If you know how to manage your routers settings check to see if upnp is enabled. This is univeral plug and play. It will auto forward ports to correct setting when requested by specific devices from inside your network
    Sent via Tapatalk
  15. #15
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This would be awesome! Let us know the youtube link!
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
  16. #16
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    Ah, you lost me at routers... lol
    Is there a tutorial for what your suggesting?
    Thanks!
  17. #17
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    No not really on the router bit.
    Quick question. Do you or have you ever played halo on xbox live multiplayer. If so have you ever seen on the tv screen that you have a moderate or strict NAT setting? This problem is also fixed by enabling upnp. Do you have a router that you either plug in a network cable or connect to wirelessly from your xbox?
    Sent via Tapatalk
  18. #18
    Eclipse2K's Avatar
    Posts
    Global Posts
    5,970 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    Halo 4 says it's not in real time although I feel like it is. UPnP isn't the permanent solution to solving an NAT issue either. I'm fairly savvy when it comes to networking and certain routers either mess up from the beginning or work fine and than fail to work properly later. My Linksys e3000 would randomly change from OPEN NAT to MODERATE NAT daily and at times multiple times each day. UPnP was enabled, IP settings on the XBOX and Router manually set and linked, Port Forwarding, Port Triggering, etc. You name it I did it. Solution? Dump the router and buy a Asus router with the new A/C Technology. $200 and not many devices use it yet but sure makes me future proof. My XBOX 360 is wired in case you're wondering. Linksys is great for commercial use but for in home use stay away. Seriously, D-Link and Asus are running this game right now. If Linksys has worked for you that's fine but for my friends and I it's been a disaster.
    Note: My Asus works with OPEN right out of the box. My friends have had Asus for about a year now with no NAT concerns. Hope you get it all settled.
  19. #19
    Eclipse2K's Avatar
    Posts
    Global Posts
    5,970 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    I've done this and while it works I still run into an issue. In the past, I've been able to stream music from my phone directly to my XBOX 360. I could listen to this music as background music while playing a game. Ever since I upgraded from my Thunderbolt no phone has been able to do this. Not sure why and I've lived without it. I am able to use DLNA as a direct stream but than it basically turns my XBOX into a full screen media player and not the background data I'm looking for.
  20. #20
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    I connect my PS3 Wirelessly through our home network WiFi, my TV is also connected through our Wifi... Where can I enable upnup?
  21. #21
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Upnp is enabled in your router webpage where its settings are stored.
    Eclipse you are correct, not all routers are the same any many are DOA or die just outside of warranty I have had many. Bittorrent eats cheap routers for breakfast it seems.
    Sent via Tapatalk
  22. #22
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Quote Originally Posted by Eclipse2K View Post
    I will try it both ways tonight. I have only used the full scree media player on xbox. Havent tried with games before.
    I am home now so after the wife leaves ill give it a go.
    Sent via Tapatalk
  23. #23
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    I can confirm you cant use dlna while in game. Dlna requires the use of the full system music player for some reason. However you can stream music from your pc in game. Just tried thst last part.
    Sent via Tapatalk
  24. #24
    Eclipse2K's Avatar
    Posts
    Global Posts
    5,970 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    This is the part that confuses me. PC works but my phone doesn't.
  25. #25
    Eclipse2K's Avatar
    Posts
    Global Posts
    5,970 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent via Tapatalk
    Yeah, and that's odd. I've always used top of the line models since I figure a router is a necessity and used daily. Just odd how routers show signs of failure at times. Although, I don't believe the NAT issues were a failure but rather a result of faulty firmware by Linksys. Those who installed the DD-WRT firmware noted the issues disappeared.
  1. Replies: 8
    Last Post: 10-23-2011, 03:40 AM
  2. Why am i still using android! It doesn't even work!
    By bentor1996 in forum Verizon Droid Incredible
    Last Post: 07-08-2011, 01:35 AM
  3. Replies: 3
    Last Post: 06-22-2011, 11:29 PM
  4. Why are tablets 600px when they know it doesn't work well for web
    By potatoho in forum Misc. Android Tablets
    Last Post: 04-07-2011, 03:15 PM
  5. Appbrain wants to update my Flash (but it doesn't work)
    By ArchGoodwin in forum Market Help
    Last Post: 08-20-2010, 02:49 PM
