1. soundfanz's Avatar
    The LED indicator on my wife's Galaxy Note 2 seems to have stopped working.
    She used to get green LED notifications for messaging, blue for call/missed call, and red for low battery, but this feature stopped working today.
    Anyone know a solution to this problem?
    Thanks in advance,
    Chris
    02-15-2013 03:54 AM
  2. Djnaz's Avatar
    I think there is an app called LightFlow that you can set different led colors for different notifications.
    02-15-2013 07:41 AM
  3. Lastnv's Avatar
    Reboot the phone?
    Check the settings?
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    02-15-2013 08:35 AM
  4. SpookDroid's Avatar
    I'd test the LED out and see if it's still working.
    Does it work with other notifications? If so, then there might be a setting that's been turned off. I know that there's a setting to turn off the red LED blinking while charging and/or recording video.
    02-15-2013 10:03 AM
  5. Jerry-O's Avatar
    Light flow causes the swipe ability of the Samsung keyboard to break. I use light manager now with no problems
    Sent from my SCH-I605 using Tapatalk 2
    Djnaz likes this.
    02-15-2013 06:31 PM
  6. soundfanz's Avatar
    Tried reboot, and settings. And can confirm that the LED does work.
    We installed Light Flow, no difference, might try something else.
    02-15-2013 08:00 PM
  7. Kelly Kearns's Avatar
    You can test the LED lights, among other things. Dial *#0*#
    You can use that diagnostic tool to see if the LED lights are really working or not.
    Sent from my AWESOME Note 2
    02-15-2013 09:53 PM
  8. gvlakers's Avatar
    This did nothing for me? I got a "welcome to verizon wireless. your call cannot be completed as dialed. LOL
    Did you type it correctly?
    02-16-2013 04:17 AM
  9. Kelly Kearns's Avatar
    It should bring up this:
    Try variations: *#0# or maybe *#0#*
    Now Verizon might have removed it, they talk about hidden menus for Verizon and you have to be stock TouchWiz to user it. Verizon might have removed the 0 option.
    http://forum.xda-developers.com/show....php?t=2077653
    Also, maybe try 00 instead of 0 with what I gave you.
    The article about the hidden menu.
    http://whatswithjeff.com/samsung-gal...2-secret-menu/
    Attached Thumbnails LED message Indicator on Galaxy Note 2-uploadfromtaptalk1361010316977.jpg
    02-16-2013 04:33 AM
  10. Kelly Kearns's Avatar
    Doing some searching, Verizon might not have these allowed, here is a short thread here, don't know if the LED test is in this.
    Hidden menus on the Note 2
    alizaibraim likes this.
    02-16-2013 04:44 AM
  1. ATT gophone plan on galaxy note
    By skimmy08 in forum AT&T Galaxy Note
    Last Post: 08-25-2013, 12:29 PM
  2. [BUG] Serious black clipping / gamma issue on Galaxy Notes
    By paleh0rse in forum AT&T Galaxy Note
    Last Post: 10-07-2012, 08:44 PM
  3. NFC on Galaxy note i717 ATT
    By jangleton13 in forum Introductions
    Last Post: 07-24-2012, 01:37 PM
  4. Apply theme on galaxy note
    By kusyt91 in forum Samsung Galaxy Note
    Last Post: 06-24-2012, 05:32 AM
  5. Ics on galaxy note
    By tstens22 in forum Android 4.0 Ice Cream Sandwich
    Last Post: 06-11-2012, 03:53 AM
