Results 1 to 18 of 18
Like Tree5Likes
  • 2 Post By ecs180
  • 2 Post By crystinonfire
  • 1 Post By SiriusXM
    ecs180's Avatar
    Posts
    Global Posts
    65 Global Posts
    Default Not so known battery saving tips
    Hi everyone,
    The other day i saw 30% drop in battery overnight. I had already researched battery saving ideas and had the usual settings (i.e., google now off, dim screen, etc.)
    I came across 3 different tools that helped me big time...i am currently sitting at 80% after 16 hours
    1) application manager -> swipe right to all - go through the list and disable "show notifications" for pretty much every app you don't need a notification for. also unistall updates/diasable/force stop any app you dont need (since there are a lot of random apps, only do this for obvious ones)
    2) download (all free) cpu spy (confirm your phone is hitting deep sleep), my data manager (determine which apps are using data), and gsam battery monitor (determine which apps are both keeping your phone awake, and waking your phone). cross reference my data manager and gsm battery with the below.
    3) the holy grail as someone referred to it - settings -> data usage -> scroll down to bottom -> manually disable background data for all obvious apps. i personally left my weather, email, and the android os ones alone. it is important to note that if you open your browser (or any other app) it is no longer a background app. you must do the hold home button clear open apps to close it out.
    i am pretty good with tech, but am no expert and this worked for me (so far), but if anyone knows better please let me know
    nice to see my battery finally in beast mode
    Thanked by 4:
    zmann and EjWilkes0121 like this.
  2. #2
    Default Re: Not so known battery saving tips
    Quote Originally Posted by ecs180 View Post
    Is this one still helpful if you're hooked up to wifi all day?
  3. #3
    The last option does nothing if you're always on WiFi... it only restricts the apps to NOT download any mobile data while in the background. If you open the app, though, mobile or WiFi, data can be consumed. If you're on WiFi, the app's local data policy applies (if it's polling for data in the background, it will continue to do so on WiFi).
    Thanked by:
  4. #4
    Wow,, I don't want anything using data in the background. I go to individual app settings every time I install new app and I disable if I can. I only want an app to update if I actually want to use it. I just went through the data use settings and could not believe what some of my apps were using in the background. I disabled them all. I did not disable anything important,, just apps I installed.
    Note 2, it's true, ,size is everything!
    love my evo.
    ecs180's Avatar
    Posts
    Global Posts
    65 Global Posts
    Final Stats with 17% left.
    -Normal use (intenet, text, gps on)
    -1 day 11hr
    -screen time on 3 hr 52
    -9% overnight drain (still something waking my device, think its a combination of the OS, email and weather)
    -i think this 17% would last me on normal use another few hours
  6. #6
    i have BeWeather and it lets you set "off" hours so it knows not to update while you're asleep.
    DaRkL3AD3R and Synycalwon like this.
  7. #7
    I am a bit confused with the options of disable ar force stop, can anyone help as I probably have stock things running all the time should i stop these? i don't have many added apps my phone is fairly stock but It would be great to know what I should get rid of.
    Andy
  8. #8
    Great ideas! I also turned off all vibrations and the notification lights.
    _____________________________________________________
    Best Buy now offers permanent price match against all stores including Amazon and online stores - The Galaxy Note 2 is the phone of the decade! - Tapatalk HD 2
  9. #9
    Quote Originally Posted by SiriusXM View Post
    At first I thought you worked for SiriusXM and now I think you work for Best Buy. Lol! Make up your mind already.
    But I still must say Amazon > Best Buy even with price matching. Maybe different for mobile phones I'm not sure.
    And good tips OP. I love my Note II but I sure miss the battery life of my RAZR Maxx HD.
    Sent from my SCH-I605 using Tapatalk 2
  10. #10
    Great post!
    I went on Data usage and just Selected "Restrict background data" on the top right so it generally would restrict all apps.
    Would this still auto update apps when I'm on wifi? (e.g. eMail notifs, chats) Can't test it for now, no WiFi till I get home.
    thanks!
    AT&T HTC One X - CM 10.1
  11. #11
    I was really hoping to do this, but when I went to check it on my phone there was no visible options for this? =/ the only thing I can do is "restrict background data" which I assume affects all apps. Plus it leaves an ongoing notification in my panel.
    I'm on a Verizon Note 2, ROM is Jelly Beans Build 10. I'm not sure if that affects this or not, but if someone could point out what you are supposed to see for the individual app thing I would appreciate it.
    Samsung Galaxy Note 2 on Verizon
    Jelly Beans Build 16 - Perseus 36.3
  12. #12
    Quote Originally Posted by DaRkL3AD3R View Post
    Here's what I see on AT&T unrooted: Settings > Data Usage, then scroll down and you'll see a list of apps and what they've used (first pic). Tap one and it will take you to a page for that app (2nd pic) and at the very bottom of that page is the Restrict background data checkbox.
    Thanked by:
  13. Thread Author  Thread Author    #13
    ecs180's Avatar
    Posts
    Global Posts
    65 Global Posts
    i have a verizon unrooted gn2 and i have the same screens as above
    Thanked by:
  14. #14
    Thanks guys, especially for those 2 screenshots. I see the setting now
  15. #15
    Quote Originally Posted by TheOtherBill View Post
    Omg people still use opera browser? Lol Chrome 4 life
    EjWilkes0121 likes this.
  16. #16
    Droid_Evo_8's Avatar
    Posts
    ROM
    Stock
    works wonders.
  17. #17
    I just turn off my mobile data when I'm not using it. My phone doesn't require mobile data for phone calls and standard text messages. I also use the app Juice Defender, and it turns the mobile data off when your phone is idle. This also helps when managing your data usage.
    ~¤°Holliewood°¤~
    ~*Purple Android*~
  18. #18
    Nice tips. Thanks.
    I don't care what kind of phone you have, that's not how I judge someone's worth or intelligence.
  1. little battery saving tip
    By funkylogik in forum Samsung Galaxy S3
    Last Post: 08-02-2012, 09:53 AM
  2. Photon 4G Battery Saving Tip! WiFi Sleep no more.
    By dreamliner in forum Sprint Photon
    Last Post: 07-19-2012, 06:48 PM
  3. Battery Saving Tips
    By jaybro0813 in forum Droid RAZR MAXX
    Last Post: 03-31-2012, 05:40 AM
  4. Infuse battery saving tips?
    By jmoney860 in forum AT&T Samsung Infuse
    Last Post: 01-25-2012, 07:30 PM
  5. Replies: 0
    Last Post: 06-23-2010, 01:32 AM
