Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By SenseMonkey
  • 1 Post By TheOtherBill
  • 1 Post By fade2black101
  • 1 Post By NotJustAPhone
  • 2 Post By ReuvenNY
    destefmx6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CleanROM 1.5 ATT SE
    Default 2nd Battery?
    I was thinking of purchasing a second battery from Amazon. There are 3 top sellers, but one mentions: "it works with NFC." Will a battery (EC, Qcell, Hyperion) keep the NFC from functioning on the Note 2 i317 ATT?
  2. #2
    SenseMonkey's Avatar
    Posts
    Global Posts
    1,797 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default Re: 2nd Battery?
    It shouldn't cause the nfc is built into the battery door. So as long as you get a good back door with nfc your good to go.
    Sent from my Behemoth of a phone, the Galaxy Note 2
    destefmx6 likes this.
    destefmx6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CleanROM 1.5 ATT SE
    Kind of what I thought, it seems to affect the nexus 4 mostly, which I guess it's built in to the battery. Is there a battery I should stay a way from?
    Quote Originally Posted by SenseMonkey View Post
  4. #4
    TheOtherBill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by destefmx6 View Post
    Yes, the one that seems to have too good of a price. I grabbed a chinese special for cheap just to have as an emergency backup. It's worth exactly what I paid for it - not much.
    Stick with OEM or a good name brand such as Hyperion.
  5. #5
    fade2black101's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Based on previous phones, I have always found the "Anker" batteries to be very good and very cheap too. On my old HTC phones they performed better than stock, so I can imagine they are very close to the stock Note 2 ones but for much cheaper.
  6. #6
    Nightscape's Avatar
    Posts
    Global Posts
    85 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have two extra Anker batteries and they are great. It lasts just as long as the oem battery. I don't trust any of the bargain batteries that claim to have 4000mah and so forth.. The Ankers are legit though.
  7. #7
    NotJustAPhone's Avatar
    Posts
    Global Posts
    11,776 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    GS3: CleanROM / N4: AOKP
    I have two of the Anker batteries for my Note II, and they've been working fine. Need the juice for Ingress.
    Sent from my SGSIII
  8. #8
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Would you say they perform any better than the stock ones? I really like the brand but ive been happy with my battery on the note 2 anyway so will probably only buy them if there if they last ever so slightly longer over stock?
    It's a shame about the unfortunate naming of the brand "*Anker" though :rolleyes:
  9. #9
    Posts
    Global Posts
    11,776 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I haven't monitored their performance closely, but I haven't noticed a significant difference in performance between the Anker batteries and the stock battery.
    Sent from my SGSIII
  10. #10
    Double0EK's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just ordered my Anker 6200mah battery. Hope to see it Wed. Gonna mod my battery back door and my Otterbox Case. Hoping to see good things with it.
  11. #11
    ReuvenNY's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I ordered Qcell (2 batteries) 3 months ago. Works exactly like the original OEM. Last as long. Recommended.
    destefmx6 and Double0EK like this.
  12. #12
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just thought I'd add that I find thr Mugen Power batteries to be the best.
    They are very pricey though. They offer an extended battery and a normal sized one. Thr normal sized one is usually a fair bit more powerful than stock, but given tbr already top quality battery samsung used, thr mugen one is only 100mah more in capacity so prob only a few % better than stock. The extended battery will probably double your battery life.
    Given the price, I prefer the Anker ones. (Will never get the extended battery though as I don't want the extra bulk).
    I just thought I'd mention the mugen batteries because, if you have the money, I seriously think they're the best quality ones available.
  1. I could cry - 2nd Razr Maxx...battery issues...
    By ttens in forum Droid RAZR MAXX
    Last Post: 06-22-2012, 07:15 PM
  2. 2nd Overnite Dead Battery - Keep Awake?
    By jcarson13 in forum Verizon Galaxy Nexus
    Last Post: 03-05-2012, 03:37 PM
  3. Replies: 45
    Last Post: 05-19-2011, 01:33 PM
  4. Replies: 0
    Last Post: 12-02-2010, 01:10 PM
  5. 2nd battery or larger battery?
    By crazy_vag in forum HTC EVO 4G
    Last Post: 06-22-2010, 09:29 AM
