1 Attachment(s)
Mobile phone stand for the Note 2
I came across a mobile phone stand that works great with my Note 2.
Got this one from eBay.
I like it because it has rubber contacts at the bottom, to keep the stand from sliding around on a table. It also has rubber contacts where the phone sits on the stand. I like how the stand folds flat, and the incline level can be adjusted.
I use it with the Samsung flip cover. I have the hinged part of the cover sitting on the stand. This way the phone is not resting on the power button.
[Only registered and activated users can see links. Click Here To Register...]
Sent from my Samsung Galaxy Note 2
Re: Mobile phone stand for the Note 2
that's pretty nice. thanks for sharing. just pair that with a startech right angle micro-usb cable and you're all set.
1 Attachment(s)
This is a very nice stand that's easy to carry around. Best part is its also a spare battery charger.
Note 2, it's true, ,size is everything!
[Only registered and activated users can see links. Click Here To Register...] sorry, would not let me put 2 photos in my last for some reason.
I have this one as well. I don't use it much because if I flip the Samsung Flip Cover back, it doesn't sit in the stand (volume rocker side sitting in the stand). I have to sit it on the side where the power button is. If I don't let it hang off to the right side of the case, the phone will keep turning off whenever the power button is touched.
