1. cdf3's Avatar
    Every now and then I'll be using my phone, then it will freeze up. About 5 seconds later I will get a pop-up saying "Maps has stopped working". Once I click OK, my phone starts working again as usual. This has happened to me while using various apps on my phone.
    Anyone else having this problem?
    Sent from my Samsung Galaxy Note 2
    03-06-2013 05:37 PM
  2. Jude526's Avatar
    I haven't had any issues. Try uninstalling the maps app and then reinstall. Sounds like a weird glitch
    Sent from my Samsung Galaxy Note2
    03-06-2013 06:55 PM
  3. tirith's Avatar
    Have you cleared caches or anything with any particular apps previous to this occurring? Or any task killers?
    I get a hang up while using system tweaks after clearing caches unless I reboot... And it's not only maps, poweramp, Google account services, Facebook, etc... I usually get about 8 or more consecutive.
    ~swyped from my galaxy note 2 on the now network
    03-06-2013 08:09 PM
  4. cdf3's Avatar
    Tried that. Didn't work. Uninstalling the Maps app isn't possible that I'm aware of. Since it's a system app, uninstalling only allows you to roll back to previous versions.
    03-06-2013 09:21 PM
  5. cdf3's Avatar
    I disabled Location Reporting in the settings of the Maps application. I'm hoping this will fix the issue for me.
    Update: That didn't work either.
    03-06-2013 09:36 PM
  6. rankar7's Avatar
    what carrier are you on?
    03-07-2013 08:25 AM
  7. cdf3's Avatar
    I'm on Verizon.
    I also starting getting "Settings has stopped working" error pop-ups while looking through the settings of my device.
    Not sure if apps were causing the issue, I uninstalled several apps that were running in the background when the error messages occured. So far I haven't seen any more error messages. Keeping my fingers crossed.
    03-07-2013 08:29 AM
  8. rankar7's Avatar
    I'm on Verizon.
    have you tried booting in safe mode to verify that it indeed is software related?
    03-07-2013 08:38 AM
  9. cdf3's Avatar
    Will the phone be crippled while in safe mode?
    The error messages happen a few times a week. Hate to be running in safe mode for extended periods of time.
    03-07-2013 08:43 AM
  10. tirith's Avatar
    The biggest thing... are you using any kind of task killer or battery saver app?
    03-07-2013 11:29 AM
  11. rankar7's Avatar
    No, phone won't be crippled. It'll just be running bare-bones. This way, you'll be able to tell if it's an app you've installed or if it's possibly hardware. When you re-boot normally, then your original setup will be back.
    03-07-2013 02:21 PM
  12. cdf3's Avatar
    No. No task killer apps.
    03-07-2013 03:21 PM
  13. cdf3's Avatar
    Would apps be disabled?
    03-07-2013 03:24 PM
  14. rankar7's Avatar
    it'll basically look the way when you first pulled it out of the box. i had to run safe mode to figure out what was hanging up my note2 for a few boots until i was able to figure out what was freezing my phone. after a few weeks of watching and diagnosing, it was that darned at&t voicemail viewer (home voicemail) app.
    03-07-2013 04:00 PM
  15. rankar7's Avatar
    yes, essentially you won't be able to "see" your installed apps. but hopefully you'll be able to diagnose the problem in safe mode (can you recreate the freeze in safe mode) so you're not running it in safe mode for any length of time.
    03-07-2013 04:01 PM
  16. cdf3's Avatar
    It doesn't happen enough for me to want to run in safe mode. It could happen today, then not happen again until a day or two later. That's a long stretch of not being able to use apps.
    It's very unpredictable as far as when it will happen. There's no way to recreate it.
    03-07-2013 04:27 PM
  17. rankar7's Avatar
    Ok then try to watch a few things and just note what's going on. For example:
    1. Does it happen when you enter/leave a wifi area?
    2. Does a particular app ask you to re-enter your password when you've already entered it (this means the app crashed and restarted)?
    3. Notice any charging problems?
    4. etc.
    This will start to help diagnose your problem. Unfortunately, it's going to be a gremlin until we can start to narrow it down. Let us know over the next few days what you're observing.
    03-07-2013 04:51 PM
  18. cdf3's Avatar
    4. etc.
    No problems with any of the listed suggestions.
    It did it a few more times a while ago. Didn't notice anything out of the ordinary. Decided to go ahead and do a factory reset.
    Waiting for my device to set itself back up.
    I'll keep you all updated if it happens again.
    03-07-2013 05:17 PM
  19. whitecollar's Avatar
    My note does seem to freeze when I enter or leave a Wifi area. Not always but that seems to be a commonality.
    03-10-2013 08:28 PM
  20. Roxeann's Avatar
    TRY THIS! Go to Settings - Location services - then make sure you check the "use wireless networks" and "Location and Google search". This helps my problem. =)
    05-28-2013 03:53 AM
  21. aringan's Avatar
    I am having the same problem, my phone freezes and after couple of minutes it says to me that maps has stopped working !!!! I am on T-mobile
    I tried most of the suggested solutions, non of them worked for me !!
    please someone help me
    07-11-2013 02:36 PM
  22. handyexpert's Avatar
    same here. galaxy s3. Verizon. Tried everything including a NEW phone. Nobody seems to have the answer.
    08-18-2014 08:34 PM
  23. abhishek009's Avatar
    My s2 has same issue. No resolution. Dont think network has anything to do with it.
    04-07-2015 03:33 AM
  1. Speaker phone has stopped working...
    By efyoiphone in forum Sprint Galaxy Nexus
    Last Post: 12-03-2012, 04:56 AM
  2. Maps has stopped working
    By Sesami in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-21-2012, 12:18 AM
  3. Netflix has stopped working for me
    By littlebone in forum Barnes & Noble Nook Color
    Last Post: 06-10-2011, 06:31 PM
  4. Calendar has stopped working after firmware upgrade
    By stevethepug in forum General Help and How To
    Last Post: 02-23-2011, 06:09 PM
  5. Phone Keeps Freezing up....
    By Robbie317 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 12-25-2010, 03:15 PM
