Results 1 to 9 of 9
    Default Weather Wiget Problem
    When I rebooted my phone, the weather widget is not working anymore "Problem Loading Widget" . Please help...
  2. #2
    Default Re: Weather Wiget Problem
    Try removing the widget from the screen (not uninstalling it) & then put it back.
    Quote Originally Posted by nlitenme View Post
    doesn't work...
  4. #4
    Then try fully uninstalling the app, re-installing & then putting the widget back.
    How can I do it? do you have an apk for it?
  6. #6
    Quote Originally Posted by kenner03 View Post
    Which weather widget is it?
    If it's the stock one, I don't have it, but it shouldn't be too hard to find it.
    By the way, have you rebooted again? (I just want to make sure)
  7. #7
    Turn on locations.
    Or...
    If it's a third party app see if it's updated. Because some of them are still using a discontinued weather service. That's what happened to my favorite weather app but now I just use Beautiful Widgets.
  8. #8
    Make sure you haven't disabled the widget or the weather service (Settings - Applications - All - Select the Widget or Weather service and make sure the DISABLED option is, well, disabled :P).
    If you're rooted, make sure you didn't move the app to SD card (widgets WON'T work from SD cards, period).
    yeah I rebooted and yeah it is the stock one
  1. HTC Weather wiget
    By txfarmboy in forum HTC EVO 4G
    Last Post: 01-10-2011, 11:10 AM
  2. bizarre weather location problem
    By azjerry in forum General Help and How To
    Last Post: 10-07-2010, 12:06 AM
  3. Weather app problems
    By sethlamb in forum Verizon Droid Incredible
    Last Post: 10-04-2010, 08:25 AM
  4. Google News & Weather Widget Problems?
    By fiskadoro in forum Android Applications
    Last Post: 06-17-2010, 12:59 PM
  5. Flip Clock/Weather widget problem
    By cycophuk in forum HTC Hero
    Last Post: 01-06-2010, 01:54 PM
