Results 1 to 4 of 4
    Default Network Disabled, Poor Connection problem / obtaining IP address problem
    Hello, my Galaxy Note 2 for the past week or so refuses to connect to any router, tried to put in the static IP and forget the network, restart the network and reboot my phone but nothing seems to be working, also tried to dial *#0011# and change the power save to off but that doesn't work either, any other tips other than having to take it to samsung? Thanks
  2. #2
    Smile Re: Network Disabled, Poor Connection problem / obtaining IP address problem
    Hi, I also having the same problem for the last few months, but i finally found a solution for it. first i'll tell what is the problem & how it happen to you galaxy phone.
    whenever happen to this wifi issue is when u have updated the firmware of the phone original version 4.1.1 to 4.1.2 jelly bean, the update will cause ur phone wifi connect go crazy, and
    this only happen to some of galaxy phone not all the galaxy phone. nothing going to help even u reset to the factory, bcoz the firmware of ur phone is already updated to 4.1.2 jelly bean. in this state
    nothing u can do to solve the wifi problem, bcoz the core of the wifi processes has already been modified.
    the only solution for the wifi is using the third party app to support the wifi chip in the galaxy phone. in order to do that, first u must go to the Play Store and then goto the Search for
    wifi connector library make from farproc. download & install the app, then the app will automatically run as a background process, once is done, now u should be able to connect to any wifi hotspot
    i hope the above solution will help u.
  3. #3
    Default Re: Network Disabled, Poor Connection problem / obtaining IP address problem
    Quote Originally Posted by Derrick Tew Chun Sin View Post
    The odd thing is this isn't just a Note II issue. The RAZR HD did the same exact thing.
    Sent from my Samsung Galaxy Note II
  4. #4
    thanks for the tips for fixing my wifi. Wifi analyzer with the wifi connector library did the trick. Now using 4.1.2 successfully with my note 2 and connecting to wifi with no issues!
    Previously I had to downgrade to 4.1.1 to get it to work.
  1. Cannot Obtain IP Address
    By VAVA Mk2 in forum Verizon Galaxy Nexus
    Last Post: 05-03-2013, 01:26 PM
  2. Wifi Issue - Obtaining IP Address
    By Briansuperduper in forum Motorola Xoom
    Last Post: 04-26-2013, 10:12 PM
  3. Obtaining IP Address
    By Iceycold in forum Verizon HTC Thunderbolt
    Last Post: 09-06-2011, 02:36 PM
  4. Obtaining IP Address
    By trevor in forum Samsung Galaxy Tab 10-inch
    Last Post: 09-01-2011, 11:11 AM
  5. EVO 4G Continually Trying to "Obtain ip address" at work
    By Doc in forum General Help and How To
    Last Post: 07-28-2011, 01:33 PM
